390 rebuild help decode - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2010, 12:56 PM
i need help figureing out what was done during a rebuild on the underside of the engine it has a rebuild tag in two collumns that say
HESCO mfg corp
greeley co
1 2
bore O.S V or T
6303 64AZF
6211 N
6333 N
C.I.D. 390
NO. 17162
any idea on what the numbers mean
Old 04-21-2010, 06:42 PM
aka Duke of URL
HESCO mfg corp
greeley co
1 2
bore O.S V or T
6303 64AZF
6211 N
6333 N
C.I.D. 390
NO. 17162
It is simply giving info on how the engine was redone. It lists a crank kit, rod and main inserts. NO. 17162 will most likely go back to a build sheet.
Old 04-22-2010, 11:37 AM
any idea on what crank kit and other parts
Old 04-22-2010, 12:34 PM
aka Duke of URL
You would have to contact the rebuilder. All use different ID methods. They are just using FORD P&A Basic Numbers to ID crank, main and rod inserts. Even the cyl bore OS is not given.
700R4 Rebuild Parts and Advise Questions wild_man84 Transmission - Rearend 37 04-09-2010 05:07 PM
stroker 383 or 350 rebuild rbat Engine 34 12-10-2009 02:19 PM
Question on Edelbrock carburetor rebuild kits. eric32 Hotrodding Basics 8 05-18-2009 05:19 PM
390 2v econo to 390 gt 65galaxie500 Engine 9 04-03-2003 03:32 PM
Ford 390 rebuild...What's the best year?? Bo_Jangles Engine 3 03-01-2002 04:02 PM
