Originally Posted by old fords
here's the story. On my 69 F-100 I could never get the driver side valve cover to seal. I tried 4 different gaskets and it would not seal. On the last try I was mad as I could be. I was on a back road and saw it was still leaking. I turned the truck around and floored it cause I was so mad. I was doing about 50 or so and heard something break and the oil pressure dropped  . I figured I had it knocking. I ease home and find out I broke the rocker arm shaft. I had another rocker arm assembly and put it on. I cranked it up and it will smoke bad out of the driver side pipe. All I can thing off is a bad ring since the paasenger side is fine.
You turned a minor irritation into a large problem. More likely than not a piston and valve met, perhaps more than one, and you've got a busted piston and bent valve for your efforts.
The leaking rocker cover is usually caused by the many years of torquing the little bolts against a soft gasket. This dimples the area around the bolt hole and buckles the cover between the bolts. The solution consists of two parts.
1) You clamp a small diameter pipe or a socket in a bench vise. You then locate the cover's bolt holes over the "tool" and with a ball-peen hammer, gently coax the metal around the hole back to a flat surface.
2) You go to the parts store and get some Chevy rocker cover reinforcements and put then under the Ford's cover bolts. This will work everywhere except on the corners. Here you can fabricate a adapter that goes around the corner or use a hardened washer as large as will fit.
But now you've probably got a serious problem to fix first.
Bogie
