393 w ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2012, 08:36 PM
393 w ?
i need help picking a good 393 choice for my truck
Old 06-26-2012, 10:41 PM
Just curious, Why not a FE 390, 410, or 428? Or if you get really lucky, a 406, or 427 FE engine?
Old 06-27-2012, 01:25 PM
WV hillbilly
Last journal entry: PTL 220CC
ive built several cheap 393 windsors using truck rods, KB 302 pistons and a scat cast crank that will be up to the task of truck duty.... you might want to use dish pistons with 64cc chamber heads as flat tops in a 393 build alot of compression..
you can also use the factory castings if your not going to be turning alot of RPM I port small block ford castings for 325$ a pair that will run well on a 393 but will not make power up high 5500 RPM is max
351w>393 stroker kit on gas F100Steve Hotrodding Basics 2 12-24-2011 01:32 PM
Ford 393 stroker crank SouthernRascal39 Engine 3 11-12-2009 08:31 AM
351W or 393 Carlos9 Engine 20 08-28-2009 08:31 AM
393 or 408 or 427 slow'n'steady Engine 2 05-15-2007 09:35 PM
393 stroker help 53fordguy Engine 11 06-07-2004 07:59 PM
