3931063 heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2011, 05:40 PM
396chevelle's Avatar
3931063 heads?
I have a set, and was wondering if they were a decent head. I did research on them, but I wanted here from other people.
3931063 1969 396 325, 350 2.06/1.72 100.967 Similar to #3909802 & 3917215 with two accessory bosses above #3 (or #6) exhaust ports for air conditioning rear support bracket. Straight casting flashing
Thanks,
Old 01-07-2011, 09:28 PM
airboat's Avatar
Yeah! Good heads!
Old 01-07-2011, 09:30 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
in another post did you say they have bigger than stock valves?
Old 01-07-2011, 09:33 PM
Yes, that is what I was told when I purchased the car. I tried to get as much info on the motor as I could. Those are the casting numbers for the heads, but bigger valves. I wonder what kind of flow I'm getting?
Old 01-07-2011, 09:41 PM
& matts38chev
if they do have the bigger valves in them i would run them!
if still stock ? i dont know enough about those castings to guess.
if stock valves, you might think about selling them to help pay for some better ones
Old 01-07-2011, 09:43 PM
What would be the easiest way to verify the valve size? Pull The Head? I'm sure he wouldn't lie, but you never can tell these days!
Old 01-07-2011, 09:47 PM
& matts38chev
that would be the only way
Old 01-07-2011, 09:49 PM
I'll pull it to make sure!
Old 01-07-2011, 09:56 PM
& matts38chev
while you have them off you can look at your pistons to see how much, if any, dome or dish they have.
this will make difference because, most new heads and other good used castings (781/049) are open chamber and lower your comp. ratio, if those that you have now are semi closed.
Old 01-07-2011, 10:00 PM
Thanks, for the tip! I'll make sure I take a look. I might as well change the cam while I have it apart!
Old 01-08-2011, 08:56 AM
Originally Posted by F-BIRD'88
If you have the 063 396 oval port heads you are all set. Don;t worry about wether they have large valves. The stock size 2.07x1.72 valve are fine for aand even prefered for a 550hp street/strip oval port 396.
The 396 cylinder bore is small and gets shrouded with larger valves in closed chamber heads.
the 2.07 valves are the right valve size for your 396 with closed chamber heads. The key is correct head porting.
But the heads need to be correctly ported for power.
The 550hp Joe Sherman built street 396 is build using the 063 heads with stock valve size. (althou they are probabily hi quality Ferrara or Manley SS)
The larger valves work better when on a large bore 427-454+cid motor.
For your purpose, The 2.07 x 1.72 valves are the ones to use on a 396 with the closed chamber type oval port heads.
They flow plenty plenty once correctly ported. Check out the details of that build. It's very simple yet delivers the power using fully ported 063 heads and stock 2.07x 1.72 valve size.
If you are serious and you want to do it right the first time:
You may want to pay someone like Meaux Racing Heads in Louisiana. www.maxracesoftware.com to correctly port your "063" oval port heads....
The cylinder head preparation is key and he can do it right for you.
The rest of the build is pretty basic,
Thank's guys for the great info! Meaux Racing is only about 4hrs away, so thats not to bad. I have a shop close to my work that is well known and has been around since I was a child. Do you think they would be ok to do the work or is this something that only a few can do right?
Old 01-08-2011, 09:17 AM
& matts38chev
its not magic, but you also dont want the neighbor kid doing it.
talk to them, see what they have to say, you can often get a feel about a machine shop by talking to them and some of their customers.
Old 01-08-2011, 09:29 AM
& matts38chev
do some head porting research on the interweb, so you halfway know whats going on before you talk to them.
it will help sort out BS from the actual knowledge
Old 01-08-2011, 06:17 PM
I found a set of bare 781 heads for $185 and $75 shipping, so 260 total! What is a bare set worth?
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-18-2013 11:00 PM
dart heads vs vortec heads repeat Engine 48 03-10-2012 08:05 PM
462624 SBC heads vs Patriot heads?? v8hed Engine 2 05-27-2008 09:25 PM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 04:12 PM
