We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 04-22-2008, 12:39 PM
cope's Avatar
cope cope is offline
3932388 327 or 350
i got a core short block just block,crank,rods,pistons the casting number is 3932388 mortech said it was a 327 or 350 how do i tell the diffrance
Old 04-22-2008, 12:45 PM
oldbogie oldbogie is offline
Crank will have a stroke of 3.25 inches for a 327 and 3.48 for a 350. Keep in mind that measuring from the centerline of the crank mains to the centerline of a rod journal will be 1/2 the stroke.
Bogie
Old 04-22-2008, 12:49 PM
Mustangsaly's Avatar
Mustangsaly Mustangsaly is offline
if its a 4 bolt main its a 350, if its a 2 bolt main it can be either and you will need to measure crank.
Old 04-22-2008, 01:04 PM
Double_v23's Avatar
Double_v23 Double_v23 is offline
Horsepower Enthusiast
The pistons for the 327 will have a longer compression height (distance from the center of the wristpin bore to the top of the piston) if there is a part number on the piston you could check that and it will tell you what it is for.
Old 04-22-2008, 01:12 PM
cope's Avatar
ya i droped the pan and it was a 2 bolt main. what about crank #'s can they be looked up 3932442
Old 04-22-2008, 01:55 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
68NovaSS's barnstar
Wiki editor
Wiki Edits: 9
Mortec has it:
3932442..267,305,350..cast...medium journal...3.48" stroke
You can't run with the big dogs if you pee pee like a puppy...
Old 04-22-2008, 02:07 PM
DeathRattle's Avatar
DeathRattle DeathRattle is offline
Some Punk Kid
Should be a 350 with a 442 crank.
Old 04-22-2008, 02:13 PM
Double_v23's Avatar
Yep that 442 is an extremely common 3.48 stroke crank.
Old 04-22-2008, 07:17 PM
cope's Avatar
cool thanks guys
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "3932388 327 or 350"
327 -Vs- 350 Capt. Camaro Engine 22 10-16-2009 07:23 AM
327 block with a 350 crank hollywood2k Engine 4 07-04-2006 10:06 PM
327 with 350 crank 67camarokid Engine 12 05-28-2006 02:27 PM
327 or 350? scott011422 Engine 12 04-26-2003 06:45 PM
350 crank in 327 1962MotorheadMike Engine 1 11-16-2002 06:17 PM
