396 350 375 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2013, 06:51 PM
how do i know if it is a 350 hp
or if it is a 375hp
396cu
Old 01-08-2013, 06:55 PM
RWENUTS's Avatar
The L34 (350 hp) had oval port heads.
L78 (375 hp) had square port heads.
Old 01-08-2013, 06:56 PM
poncho62's Avatar
Wiki Edits: 5
I used to know this stuff....The 350hp 396 had oval port heads, cast pistons, cast crank...The 375hp one had the larger square port heads, forged pistons and crank...solid lifter cam
Best bet is to check the suffix numbers
Ontario Rodders
Old 01-08-2013, 07:07 PM
BOBCRMAN@aol.com's Avatar
350 horse. Q-jet carb, oval port heads, cast pistons, hyd lifters.
375 horse Holley carb, aluminum intake, rectangle ports, forged pistons. solid lifters.
Old 01-08-2013, 07:14 PM
396 350 375
Well the first thing to do is get the casting number from the flange the transmission bolts to. I think its on the passenger side. Then same flange on the driver's side there is a casting # starting with a letter with 2 or 3 numbers. Example: C28. On the front passenger side right below where the head is bolted, there is a flange with the engine ID numbers unless the block has been milled. You can either post them here or look them up on this wesite. Chevy Casting Number identification - Block casting numbers BTW the heads also have casting numbers under the valve covers.
T-350 or T-375 E.Furgal Transmission - Rearend 5 10-18-2012 05:36 AM
Rare 396/375 or just another 396? LilHerm Engine 4 06-11-2012 11:43 PM
rebuliding a 350 to atleast 375 horse? runway1589 Hotrodding Basics 19 05-24-2011 07:46 AM
Stock 70 Chevy 396 375 hp questions beertracker Engine 7 01-11-2011 06:05 PM
Is it a 396/350 or a 396/375 hollywoodbob Engine 12 07-30-2003 10:51 AM
