Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 05-12-2002, 11:37 AM
WalterJ WalterJ is offline
Post 396 with a 5-speed?
Can a Borg-Warner 5 speed from a 350 Camaro be mated up to a 70 Chevelle 396 currently set up with a Muncie 4 speed with .331 rear? Would this be a terrifyingly difficult thing to pull off and can that trans actually handle the torque of a big block chevy? (350hp-350lb/ft)
Old 05-12-2002, 02:48 PM
Tom Tom is offline
Post re: 396 with a 5-speed?
No that bigblock will tear it apart
Old 05-12-2002, 03:17 PM
JdOwNj JdOwNj is offline
that tranny will blow chunks with anything other than a stock sb, let alone a 396
Old 05-15-2002, 08:42 PM
reddwarf reddwarf is offline
it will bolt up. Big and small Chevy uses the same bellhousing.
Listen to these guys though. Definately keep the Muncie, they are strong.
You just looking for an overdrive?
Old 05-20-2002, 02:22 AM
deuce_454's Avatar
deuce_454 deuce_454 is offline
no five speed short of a TREMEC 5 speed tranny wil withstand the torque of a bog block, the onlt overdrive transmissiont i know of that can talke teh abuse is a Richmond ROD and a Borg Warner T.56 wich both are 6 speeds. id stick with the muncie.
It is possible though to build a 700-R4 that kan take a Big block's abuse. i have one in a 66 implala with an ls6 in it and believe it or not it hasnt exploded. but they are not cheaq
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
