Thread Tools Search this Thread share on Facebook
  #16
Old 06-23-2010, 08:06 AM
Barry.M's Avatar
Barry.M Barry.M is offline
Old Phart
Last wiki edit: How to identify a Ford V8
Last journal entry: 27 T Roadster project: Underway cont.
Wiki Edits: 3
I tend to agree with 454C10, if it ran great before the upgrade I'd put it back to that. Then look arround for another cheap carby, rebuild it at your leisure and then wack it on when it's ready. That way you've got a spare !
Register now (free) or login to remove ads
Old 01-22-2012, 12:29 AM
ratman33 ratman33 is offline
i did same change but put a 750 hp main body on 4779 750dp.it also ran good but now has low stumble also.i dont have power valves and ran 81 and 86 jets before.left everything the same as place to work from.now it flows more air and doesnt work same.car craft did this also recently and they reduced high flow air bleeds to .026 which makes it fatter and helped fix it.my main body kit came with 72 and 84 jets for holleys suggest starting point with power valve.i cant tune right now because it is to cold have to wait till it warms up.but it should work better when get lined out.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "396 BBC holley 750 HP upgrade -- dead spot now"
ThreadThread StarterForumRepliesLast Post
Holley 750 rebuild or replaceclarkdchevelle69Engine702-10-2004 09:20 PM
Holley 650 DP Mec Sec or 750 Vac SecDTL504Engine712-29-2003 04:25 PM
Holley HP / Demon / Proform ?nastynovaEngine609-16-2003 09:43 AM
dead spot holley helpslammedchevy86Engine306-12-2003 06:06 AM
600 cfm holley vs 750 cfm holley85 regalEngine711-27-2002 06:25 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
