396 bbc into a toyota land cruiser , bad idea ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2013, 10:46 PM
Im building a 71 fj40 land cruiser for 4wheelin and some daily driving. Using a 700r transmission and a transfer case thats geared low . Long hours of idling and low speeds over rocky trails when 4wheeling . Most guys run a stock sbc 350 , good power , ok gas mileage. I have a 350 to use but.....
I have a this motor that was my dad's , It's a 1966 ss 396 from a chevelle.
It has the square exhaust port heads. I know it would be over kill and i dont need that much hp. But the thought of my dads 396 brings on a smile .
Ive never drove anything with a bbc so im not sure what to expect
I think trying to keep it running cool and the gas mileage would be a deal killer.
What do you guy's think ? Should i save this motor for another project and use the 350 instead?
This is not my rig , but this is what it will look like.
Old 02-15-2013, 11:44 PM
327NUT's Avatar
I know about sentimental values but the 396 with the big rectangular port heads are more suited for high rpm not low end grunt. You could still build a cheap 396 with oval port heads that would be good....but since you have the 350 why not just use it and save your dad's engine for something really special.
Old 02-16-2013, 07:09 AM
BOBCRMAN@aol.com's Avatar
ALL 396 and all iron head big blocks are square port exhaust.
Old 02-16-2013, 07:11 AM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
X 2 with Nut. Keep the Rat motor for a nice chevelle, or a caprice.
A SBC in your F2 would be a great attribute, especially since there is so much support for it out there. Kinda nice to be able to buy parts about anywhere for your daily driver/rock crawler .
Fact is stranger than Fiction
Old 02-16-2013, 08:37 AM
kso's Avatar
kso kso is offline
That (BBCs suck gas bad just to keep at idle), plus the whole rest of the truck (frame, suspension, driveline) would need to be upgraded to deal with it...not just the power, but the weight. For all of that, it'd be fun for short bursts or on the dunes but otherwise just a conversation piece.
As mentioned above, the rectangle-port difference in heads applies to the intakes, not exhaust. Oval port intakes common and torquey, square-port hi-hp/rpm stuff. What ever yours is, like they say...keep it around for something else.
Old 02-16-2013, 09:37 AM
In a vehicle as heavy as a Land Cruiser, the big block isn't really that "far out". Using an "RV" cam, Performer, peanut-port heads, that thing would climb the Empire State Building. The downsides are mounting it (kits for small blocks are everywhere), whether or not the 700 is up to the task is doubtful (TH200-4R is stronger once modified), and BBC is not a "cheap" engine to build. But it's bullet-proof and under 4,500 RPM, would live forever. "Custom" headers are another expense.
Since you already have the 350, building a 383 with similar characteristics of the above 396 would be my recommendation. While 350 is a good engine, the added stroke would provide more low-end torque, your ultimate "goal" with an engine of this application. The small block is the economical choice, as there are kits available that include all the mounting system and headers. Very little "custom" work is necessary.
If money isn't as important as "performance" (using your parameters), a "428" BBC is a GREAT torque monster. Using a 454 crankshaft in the 396 block gives the best of "both worlds", by adding stroke without increasing bore. With proper preparation on the heads and a good cam choice, it would rival the 428 Pontiac for low-end and mid-range power. If you're not familiar with them, ask some of your non-Chevy friends about the potential torque output of the Pontiac. Yes, a low-speed BBC can do it, too. It would require "custom" pistons, which aren't difficult, just expensive.
The fuel consumption of these BBC configurations would surprise you. One 396 in a Corvette was checked for a year, and managed 17 MPG, while beating a Viper in it's only "speed contest". Low-speed engine (5,400 RPM peak), tall gears. I would think in the much heavier Toyota, the 428 would provide better fuel economy. Don't overlook the weight when considering fuel consumption. A small block has to "work" much harder to do the same job.
If "cool factor" is a consideration, BBC, without a doubt.
Jim
Old 02-16-2013, 10:22 AM
Yes, the land cruiser is going to be heavy. I was thinking of the 396 for the coolness factor and the sentimental value. It would take more fabricating to make the bbc fit. But i think your right about the 383 that might be the best all around .
Thanks for the help.
Old 02-16-2013, 02:19 PM
A little tool that may help you!
Whether BBC, SBC or anything else give this site a quick peek, they have a little handy tool that fits inside your smartphone and may help you a lot with your engine buildup.
http://www.hotrodderapps.com
Old 02-16-2013, 06:21 PM
Back in the late 70s,we had 22 Cruisers in our club,and had anything from later model Chevy 6s to 283s, 350s (I had a 300 hp 350 in mine) but the coolest one of them all was my buddy Jerrys with a 1969 455 Olds and 400 TH,he never even bothered with low range,(didn't need to!) in this day of 4.00 a gal. gas ,I'd save the "96" for something else...JMO
Toyota Land Cruiser Swap MI2600 Hotrodding Basics 4 06-13-2008 09:06 PM
old land cruiser guy, mostly here for body and tech stuff dieselcruiserhead Introduce Yourself 4 04-02-2007 01:27 PM
Land Cruiser / Hdj81w / 1991/ Turbo Diesel saadi Hotrodders' Lounge 0 07-20-2006 07:25 AM
Hand made half doors for a Land Cruiser ehsankiani Body - Exterior 6 04-06-2006 07:29 PM
1988 chevy s-10 blazer, and i want to put a 327 in it. comments, good idea bad idea. 1969css Introduce Yourself 1 12-22-2004 05:18 AM
