396 Cam Bearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2008, 01:22 PM
Last journal entry: The Last of My Vehicles
396 Cam Bearing
I just picked up my short block from the engine shop. Its a 396 BB casting #3955272. When I took it over the engine builder said the block was an early 65-66 block and would need a grooved cam and bearings. I have the cam and went ahead and had him install the bearings. After checking the casting myself I found the block was a 69 and did not require the grooved cam. I checked the last bearing and it has a groove in it. I have not grooved the cam yet.
Can I run the ungrooved cam with the grooved rear cam bearing since the engine does not require it? Or do I either need to groove the cam or install the correct bearing?
Old 06-11-2008, 01:46 PM
the #5 cam bearing housing bore is aprox. .010 larger on 65 and 66 396 engines. you need to get the correct bearings and cam for the 69. the clevite # you need is SH-616S for the cam bearings.
sam-missle
Old 06-11-2008, 02:05 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
You definately don't want the grooved bearings. Chevy changed this for a good reason.
Old 06-11-2008, 02:37 PM
OK....well he made them fit I guess.....like I said the block is 3955272, so I don't know how he got it confused. But, I can see the rear journal has a groove in it. I'm frustrated to say the least....this is going to be a blown engine with a 8-71 blower. How could the mismatch even be installed?
Old 06-11-2008, 02:42 PM
Double_v23's Avatar
Apparently your machinist was not concerned with a .012 press fit!!!
Old 06-11-2008, 02:44 PM
I sense some future trouble if its not corrected too I guess
Old 06-11-2008, 03:09 PM
King of my Man-cave.
sam-missle
This is incorrect. The #5 camshaft bores on all 396 engines are sized at 2.1295"-2.1305". The only difference is that the '65 and '66 engines have no groove behind the cam bearing, necessitating a grooved rear cam journal and /or beariing to provide proper oiling. The '67 and later blocks had a groove machined in the rear cam bearing bore to provide for proper oiling. Using a grooved cam and/or bearing with the later engine can cause a reduction of oil pressure.
tom
Old 06-11-2008, 03:34 PM
[QUOTE=machine shop tom]This is incorrect. The #5 camshaft bores on all 396 engines are sized at 2.1295"-2.1305". The only difference is that the '65 and '66 engines have no groove behind the cam bearing, necessitating a grooved rear cam journal and /or beariing to provide proper oiling. The '67 and later blocks had a groove machined in the rear cam bearing bore to provide for proper oiling. Using a grooved cam and/or bearing with the later engine can cause a reduction of oil pressure.
tom[/QUOTE
sorry you are right, i guess i need to learn to read the bearing catalog a little better.
sam-missle
Old 06-11-2008, 03:59 PM
tom
Thanks Tom, the groove in the bearing is very small....with my "ungrooved cam" do you think I'll have problems with a high volume pump???
Old 06-11-2008, 05:27 PM
Do yourself and your engine a favor by using the correct rear cam bearing and selling the HV pump.
tom
Old 06-11-2008, 09:16 PM
tom
Ok, thanks Tom and also everyone else....the HV not a good idea??
Old 07-01-2008, 02:10 PM
Well I'm going to change the bearing to an ungrooved as suggested....I'm using the coated dura-bond bearings which were in the neighborhood of $50. I probably cannot replace only the rear bearing....do I have to remove the crank to change it? Or do I have to remove the other bearings to get to it?
Old 07-02-2008, 12:57 PM
Double_v23's Avatar
Yeah you have to remove the crank to change it.
Cam Selection and Dynamic CR Arcuden Engine 8 03-23-2008 11:03 AM
Cam bearings 350 chev, cam wont fit in front bearing???? JD's camaro Engine 5 02-07-2008 03:33 PM
Cam bearing wear question Mad Maggot Engine 3 12-02-2005 01:15 PM
Carrier bearing preload? Sixshooter Transmission - Rearend 11 11-10-2005 11:35 AM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 11:29 AM
