396 Motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2003, 04:54 PM
New Member
Post 396 Motor
I was just reading another post about some good flowing heads from 70 to 73 on a Big Block chevy. I dont know my casting #'s but I will find out. But the post said these were excellent flowing and can out perform some aftermarket heads. Since I heard this before, I decided to keep my stock heads on my 72 396. But what I didnt know was that the post said that these years came with a steel crank. Is this true?
Old 02-19-2003, 06:55 PM
BOBCRMAN@aol.com's Avatar
Post
low hp. 402 BB 70-73 were cast iron crank motors.
Old 02-19-2003, 08:03 PM
abe abe is offline
Post
Most big blocks had steel cranks up to 1971. after that all big blocks and small blocks horse power levels went down to unleaded fuel and the EPA required major changes in the automotive engines. But the best oval port factory heads are from 1971 -1974 which are semi open chamber with 113 CCV. the casting #'s are 336781, 353049, 3999241 ( got these on my big block ) and 3993820. these heads are great up to 6500 rpm. And they are outstanding street screamers with a high lift with a short duration cam and a stout holley.
Old 02-20-2003, 05:16 PM
New Member
Post
Hey Abe is there a chance my 72 BB Camaro came from that shortened strike year with a left over steel crank? Any way to tell? Dont say pull the pan. Just putting this thing together after 2 1/2 years, I want to start the damn thing already!
Old 02-20-2003, 07:37 PM
abe abe is offline
Post
More then likely your engine has a cast crank. Best way to tell is to climb under the engine and remove the cover for the torque converter that covers the flex plate. If its an automatic. you will need a flash light to look at the crank flange where the flex plate bolts up to it. the flange will have a parting line about 1/8" for a cast crank and a steel crank will have about an 1/2" parting line. Now if u have an manual trans u may need an inspection mirror for u to see with the flash light and if u dont see the parting line u may need to turn the engine over slowly until u can see it.
