Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 396 SBC Build
Thread: 396 SBC Build
Old 11-23-2011, 12:54 PM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Wiki Edits: 326
Always begin with the most cubic inches you can muster if you're looking for a combination that will pull like Jack the Bear on pump gas. My best advice for a street or street/strip motor would be to look for a combo that makes at least 400ft/lbs of torque at 2000 rpm, then reaches peak torque at 3500-4500 rpm, depending on the rear gear ratio.
There are a couple of 400 combos on this list of motors that I Dyno-simmed.
http://www.crankshaftcoalition.com/w...m_combinations
There are 108 combinations listed here. Knock yourself out....
http://www.ryanscarpage.50megs.com/combos1.html
