3963512 Big Block Chevy - Help!
Hello gents.
Picked up a 3963512, 2 bolt main, .030 over bare block today. Date code is H19 70 which I assume means it was made August 19, 1970. My problem is that I can barely / can't make out the stamped code in front of the front passenger side cylinder. If any of you can help me with this I would be greatly appreciated. It looks like "T08" then a "7" or a "3", then a "1", followed by a space then its a "2" or a "P", followed by what looks like a "D" or a "J". I know these blocks can be quite valuable, but I am guessing that unless I can make out these numbers or figure out exactly what vehicle this block came out of, I will never really know. Any other ways to identify this block? I also got a forged crank in the deal and I know you guys are gonna think I am nuts, but it has NO casting number on any of the counter weights and no casting lines at all. Anyone every seen anything like that? The only identifiers I can find on it are stamped into the front counterweight. Top number is either: 0T4544000 or QT4544000 and then the number below that number is either: 0T-039 or QT-039. I am thinking it is forged because when I strike one of the counterweights with a wrench I get the high frequency "Ping!" sound as opposed to a thud type of sound. Anyone that can help me identify the block and the crank more precisely would be greatly appreciated. Also an approximate value on the block. In doing some research I have seen that casting number going for anywhere between $500 and $2700. Thanks. Brent |
that casting number and date tells me it came from a 1970 454 LS6 Chevelle which is very rare and very expensive. GREAT FIND.
you can use a black powder to help you read the casting numbers on the passenger pad but do not destroy them as it will hurt the value ive seen them blocks sell for 5 grand on ebay and the LS6 chevelles came with forged cranks . that block will go .125 over with no problems at all with room to spare those are the thickest castings gm ever made. Last edited by BigChevyFTW; 06-24-2012 at 10:26 PM. |
Thanks for the reply. And I am far from an early big block Chevy expert, but wouldn't the LS6 have been a 4 bolt main? Mine is only a 2 bolt main. Any idea what the stamped code on the pad means (i.e. what the engine came from exactly)?
1969-'71 427/454; 335 to 450HP; both 2 and 4-Bolt, inc. COPO engines- but would have been a 4-bolt. Suffix "PD" or "PJ" doesn't show up in the databases I checked, that could mean it's just not listed, you misread it or it may be a truck block. Crank is a 4" stroke aftermarket BBC cast nodular iron crank made (or imported) by RPM. I believe that it's the cheapest new BBC crank available anywhere; a new one costs $277.
Cobalt-
Thanks for the info. After looking at the website you linked, that's definately the crank. Guess I will just throw the block up on eBay and see what I can get for it. Thanks again for checking the pad numbers. They are all but missing. Very difficult to read. |
![]() I just checked on mailing out 2 SBC heads via USPS. Two separate boxes (70 lb limit, one head is about 50 lb), about $25/per box. |
Duplicate post for some reason. Thanks again.
| Big block pil pump on small block Chevy | dallam11 | Engine | 22 | 03-24-2012 07:36 PM |
| Big Block vs Small Block Chevy | bigjoedo | Engine | 82 | 05-03-2010 03:36 PM |
| Big Block Chevy ... How much does a block weigh | Rob Keller | Hotrodders' Lounge | 5 | 03-24-2008 06:10 PM |
| Aftermarket Block Big Block Chevy | camaro 68 | Engine | 2 | 09-15-2003 08:19 PM |
| 55 chevy small block to big block | ehchvac | Engine | 0 | 05-02-2002 08:23 PM |
