396SS Power Kit-Wanting 350-400WHP - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2011, 05:09 PM
Hey fellas!
Picked up a 1966 Chevelle SS with the 396/360 motor.
Seems to be completely stock.
Wanting around 400 HP, going to keep my power steering etc. So nothing extreme.
Does anyone know about the Edelbrock 2095 package?
Can anyone suggest what I may need to achive the 350-400WHP mark?
Thanks and I apreciate any comment/tips/suggestions!
Old 09-03-2011, 05:45 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Not sure what you mean "WHP".
Semper Fi
Old 09-03-2011, 05:54 PM
Wheel Horsepower...
Old 09-03-2011, 10:29 PM
That kit should make 450hp (360whp) on a 396.
but will need 3.73 gears and a 3000 stall converter if you are using an automatic trans.
Old 09-03-2011, 10:42 PM
Would I need any other supporting modifications? Is there a cheaper way to make that much horsepower?
Old 09-04-2011, 06:22 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Nitrous...
Old 09-04-2011, 07:45 AM
what gear and trans/stall are you using now?
yes, no2 would be an easy and cheap hp fix. A 150hp shot would be ok for a stock bbc.
Old 09-04-2011, 10:18 AM
Running a Muncie 4speed.
Not wanting to do nitrous in this ole gal
Old 09-04-2011, 11:07 AM
The 4 spd helps a lot.
what gear?
Old 09-04-2011, 07:42 PM
Going to order the isky cam setup (.544/.544,218/218,270 duration.)
... and send my factory 66 396 heads to go get worked at a local shop.
Any suggestions on header's, intake manifolds, and a new carberauter????
Old 09-04-2011, 08:09 PM
3310 750 holley.
regular rpm intake (not air gap)
any long tube 1-3/4" header will work. Look for a header with a 3/8" thick mounting flange.
With a 4 speed, that cam should work well with a wide range of rear end gear ratios. 3.08 to 3.73.
Old 09-04-2011, 09:21 PM
3310 750 holley.
How aggresive will that cam be?
Also anyone found a cheaper set of headers that fits a BB 66-67 Chevelle without a hammer etc??
Old 09-05-2011, 07:27 AM
not very aggressive. but should lope a little on a 396.
what is the lobe separation angle of the cam? (LSA)
I would also use and oil additive with that cam. zddplus.com
Old 09-05-2011, 06:19 PM
TTT
new guy here wanting to say hi to all step1958 Introduce Yourself 3 08-20-2011 01:24 PM
69 396ss conv. W/sluggish 396 Oldguyharley Introduce Yourself 1 07-17-2011 07:44 AM
just wanting to say hello! ffclaudio Introduce Yourself 3 01-29-2006 09:37 PM
Wanting to say Hi! 1streetrod4u Introduce Yourself 4 01-13-2006 08:02 PM
Wanting to be SURE richamer1 Body - Exterior 6 09-17-2005 11:43 AM
