3970010 Block Please Help!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2008, 12:51 AM
i've got a 3970010 GM block. The Suffix code is TP. I can't find that code on anyones list....Please help me find out what i'm working with. Thanks.
Old 05-21-2008, 09:00 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Best to ask over in the Engine forum.
Old 05-21-2008, 06:31 PM
poncho62's Avatar
Wiki Edits: 5
Moving it....I cant find anything on TP either.
Old 05-21-2008, 07:08 PM
j-jock's Avatar
Are you referring to a suffix on the casting?
Are you referring to a suffix on the casting, or the suffix on the serial number on the front right side of the block?
Below are the stock applications for the 010 block:
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
If what you are talking about is the suffix on the serial number, then that just refers to the transmission and accessories that came with that specific engine. I have lost my list, but Super Chevy had an extensive list of the codes for nearly all the engines. I'll keep looking for my list, and if I find it I will post the results.
Bob
Old 05-21-2008, 09:07 PM
Thanks Bob, i found TP on the front passenger side of the Block.
Old 05-21-2008, 09:25 PM
SSedan64's Avatar
Suffix
I didn't see TP either. Here's a link to check. Maybe check to make sure there's not 3 letters instead of 2.
http://www.chevymania.com/partsid/su...fm?block=Small
Old 05-22-2008, 09:13 AM
XNTRCI-T's Avatar
AKA Lee in KC
NastyZ28 shows TPB and TPC, both are 1971 307ci 200hp out of a C1500 van or bus chassis.
Old 05-22-2008, 06:06 PM
Any possibility of a TB code?....010 Blocks are 4.00" bore.
Shane
Engine ID crash Engine 10 10-01-2006 07:43 PM
Small Block ID Help bluesman123 Engine 4 05-23-2006 10:07 PM
Decoding Ford Small block hotrodgs Engine 16 05-14-2006 06:15 AM
3970010 Block 3973487 Head What To Do? LARRY2571 Engine 3 03-14-2006 01:13 PM
