Thread Tools Search this Thread share on Facebook
  #1
Old 12-17-2011, 11:56 AM
sgt111 sgt111 is offline
3970044 block ID number
Hi, first time on site. My son is trying to identify his engine he bought to rebuild. I have read many postings on the net with the same problem we have. The block casting number (drivers rear at back of block) is 3970044. No one seems to think this correct, but that is what it is. We do not know what the engine came out of. The number on the passenger side of engine on the pad are 14L192810 then 10219CMA. I believe it is a 350. Can anyone help with the engine/block info?
Thanks
Register now (free) or login to remove ads
Old 12-17-2011, 10:34 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is online now
Last journal entry: Fresh paint
Wiki Edits: 9
Give MORTEC a try.
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne
Midnight Sun Street Rod Association
Old 12-17-2011, 11:02 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Socially Unsociable
More than likely, your block is a 3970014. However it could be any of these two:
3970014 350 68-79 200-255 car & Truck 2 & 4-Bolt
3970024 307 69-73 115-200 car & Truck 2-bolt
To check and make sure it`s not a 307 measure the bore diameter. If it`s a 307 the bore size will be less than 4 inches. If it`s a 350 the bore size will be 4 inches.
CMA 72 307 Pontiac 130 L-14 TH 350 2-Brl A.I.R., Ventura II
CMA 72 307 Nova 130 L-14 TH 350 2-Brl A.I.R.
CMA 72 307 Chevelle 130 L-14 TH 350 2-Brl A.I.R.
CMA 72 307 Camaro 130 L-14 TH 350 2-Brl A.I.R.
CMA 74 350 Nova 145 L-65 TH 350 2-Brl
CMA 74 350 Impala 145 L-65 TH 350 2-Brl
CMA 74 350 Chevelle 145 L-65 TH 350 2-Brl
CMA 74 350 Camaro 145 L-65 TH 350 2-Brl
CMA 78 350 Chevelle 170 LM-1 TH 350 4-Brl
CMA 91 350 Impala 185 L-05 700R TBI
Old 12-18-2011, 12:07 AM
thanks, but is definitely 44, I have have five people read it. Its had paint removed and wire wheeled to make sure of the number.
Thanks again
Oh, and it had a two barrel manifold on it.
Old 12-18-2011, 02:03 AM
Socially Unsociable
As said, measure the bores. Also check the date code on the rear of the block. If it indeed says 44 it`s simply a miscast at the foundry when the block was poured.
Old 12-18-2011, 03:33 AM
will do, thanks
Old 01-04-2012, 12:22 PM
MSA-1's Avatar
MSA-1 MSA-1 is offline
MSA-1
Thanks
The 044 block was a short run casting (low volume) thru the Tonawanda engine plant and was not to well documented. The VIN sez 1974 Los Angeles car. CMA was used in Camaro, Chevelle, Impala and Nova in 1974. Out of these, only Novas were were being assembled at LA in 1974.
Last edited by 68NovaSS : 01-05-2012 at 05:00 PM. Reason: Advertising. Please see: commercial posting guidelines.
Old 01-04-2012, 07:00 PM
TroyBoy's Avatar
TroyBoy TroyBoy is offline
Psychomotors
Nice MSA-1, I have one of your books. Very handy
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "3970044 block ID number"
ThreadThread StarterForumRepliesLast Post
3970044 block ID numbersgt111Hotrodding Basics612-19-2011 03:49 PM
Help With Gm Big Block Vin Numbers75160eGeneral Rodding Tech210-28-2007 08:45 PM
engine block numberClint GardnerEngine507-03-2006 08:05 PM
block VIN and casting numbersweetcamaro69Engine206-05-2006 09:12 PM
350 block numberdwaneEngine206-06-2004 09:55 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
