3m adhesives - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2013, 07:33 PM
3m adhesives
would like honest opinions about 3m panel adhesives and is it easy to use.
Old 05-03-2013, 08:01 PM
It is very easy to use and it can hold a complete car body together if you so choose to. On a BMW 7 series the factory guidelines have you bonding the frame rail! We are talking FRAME RAIL, totally bonding it without a single weld.
Check out my son's science project from a few years ago. Welding or Bolting vs gluing panels on, a science project...
Old 05-03-2013, 09:58 PM
Your son should be about 16 now? I'll give him a science project for the high school science fair that will take the cake: ice nucleating bacteria using Pseudomonas syringae. Adding the bacteria to the water makes it freeze instantly! It's the only thing cooler than panel glue beating out a weld.
Old 05-04-2013, 07:03 AM
My son isn't the one that is going to do that, it would be my 12 year old daughter (12 yesterday), her and her friend won first in the science project competition last month with one on short term memory among different ages. This little girl is really something.
Old 05-04-2013, 07:36 AM
Did married men have the shortest (or most selective) memory?
Old 05-04-2013, 05:39 PM
panel adhesives
Thanks for the thread Brian........ most interesting gonna go with it
Old 05-04-2013, 05:59 PM
But be sure to study it well, where are you using it? You can't do an open seam that is then going to be bondoed over. You want to have clean metal where it is applied ground with 36 grit (usually, read the tech sheet) and squeeze it out, then brush it over all the bare metal that will be touching, on both surfaces then put another little bead over it and clamp them together but not too tight, you don't want to smash all the adhesive out.
These are just a couple of notes, you really want to read the tech sheet on the exact product you are using and post back here so you can get any further info.
Old 05-04-2013, 07:10 PM
Pats55's Avatar
panel adhesive is great stuff. Clecos work really well with the panel adhesive sometimes, when it's really hot out you have to work pretty quick and the clecos go in and out fast when you're in a hurry before the glue sets up
Old 03-15-2015, 10:02 AM
1971BB427's Avatar
Never used this method. What do you do with the holes after the adhesive sets up? Can they be welded in, and not damage the adhesive from heat transfer?
adhesives jackodom Body - Exterior 2 01-12-2007 04:51 AM
panel adhesives? CWD Body - Exterior 10 02-19-2006 02:32 PM
Head adhesives? HemmiGremmie Engine 5 11-17-2005 06:30 PM
Adhesives ricks032003 Interior 0 09-04-2004 06:33 PM
Fusor adhesives axle bastard Body - Exterior 4 06-05-2003 12:53 PM
