3M Bristle Discs - Anyone use these?
Somewhere in my travels I saw a recommendation for 3M bristle discs to remove surface rust and paint from panels. Anyone try these? What do you think? My car was soda blastd and primed, then set under a tarp for months outside. The panels have plenty of surface rust & cheapo primer that I need to get off. Thanks in advance, Darren
http://www.shop3m.com/61500139011.ht...KU=61500151461 |
I use them-they aren't for everything (I like Rolocs mostly) but they do come in different "Grits" are clean things up nice-
I am certainly no body man and have never used them, but you might want to consider what you are going to coat the parts with when you start over.
If you use epoxy primer (which is what I will be doing), read the recommendations for the product you will be using. I am using SPI epoxy and it recommends things be sanded with 80 grit. I do use the 2" roloc disks in tight places though. I think they are 50 grit. As far as paint removal..I have been getting the majority of it off with paint stripper. If it has been blasted and sprayed with cheap primer...i bet it comes off pretty easily with whatever method you choose. |
Thanks for the input guys. I think one of the selling points I heard was the design keeps heat down due to the air between the finger bristle things. The 50 grit they come in will probably mean I'll pass & just use a DA with 80 grit. If they were available in 80 grit I'd try one. I may find a place for one somewhere before it's all said and done, but for now I'll skip it.
Brian, I'll be using Epoxy primer too, likely from Southern Poly as well. I agree it makes sense to follow the process they recommend. |
3M Scotch-Brite Bristle brush
I typically use the 50 grit and go over it with a 80 grit DA and then I am good to go with paint. * For the 1", 2" and 3" a pneumatic right angle grinder will work fine. * An electric 4.5" grinder is highly recomened for the 4.5" discs. The bristle really like the torque from the electric tool. Last edited by edselman59; 09-19-2008 at 02:28 PM. |
i use the 3" disk that look like a harden pot scruber. i have even used one on my 4 1/2 grinder . takes paint off very well doesn't hurt the metal.
| Bristle or coating removal discs? | Gearhead forever | Body - Exterior | 2 | 10-02-2006 02:36 PM |
| Bristle Discs | 35WINDOW | Body - Exterior | 9 | 09-27-2006 02:53 PM |
| bristle disc | Ranchero_65 | Body - Exterior | 1 | 07-04-2006 10:50 AM |
| tough transplant - discs for miniature rod | grouch | Suspension - Brakes - Steering | 16 | 05-16-2005 09:14 PM |
| 3M "plastic" bristle cups? | jcarter | Body - Exterior | 2 | 02-01-2005 08:25 AM |
