3M super trim adhesive - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2009, 12:24 PM
71corvette's Avatar
is this glue strong enough to bond leather to a ABS door panel? or is there a better option
Old 01-08-2009, 05:58 PM
The 3M adhesive will not hold in the heat of summer. As soon as it gets hot, the leather will pull away. Go to (your Auto Trim Store) and purchase Weldwood HHR contact cement. This is high temp glue for upholstery. I learned the hard way. Google "Your Auto Trim Store" this is the place to purchase the glue. Buy a gal, You will use it on everything.
Kirk
Old 01-08-2009, 06:24 PM
71corvette's Avatar
Kirk
what do you use to spray it?
Old 01-08-2009, 08:50 PM
life is a temporary assignment
Your Auto Trim has what you need... You can buy it by the gallon,or spray can.
ID:	35475   Click image for larger version
Old 01-08-2009, 09:01 PM
71corvette's Avatar
thanks, the spray cans would be easier. I just need to do 2 door panels and a headliner on my 50 chevy truck. are the spray cans the same glue as the gallon can.
Old 01-09-2009, 08:02 AM
DanTwoLakes's Avatar
Wiki Edits: 22
3-M super trim adhesive is a high temp contact adhesive and will work for a door panel, but not anything overhead. Just make sure you're not using 3-M 74 or 3-M 77, they will not work at all. There are no aerosols that will work for a headliner, at least their manufacturers don't recommend them for that application. The DAP HHR spray grade would be your best bet.
Old 01-09-2009, 12:48 PM
71corvette's Avatar
I have some old gravity feed primer guns 1.4 tip size. will that spray the glue?
Old 01-09-2009, 01:23 PM
Wiki Edits: 22
You need an absolute minimum 1.8MM nozzle, and 2.0 or 2.2MM would be better. Why not go to Harbor Freight, either online or to an actual store, and get part #43760 which is an HVLP external mix siphon feed spray gun which costs $17. It is all set up with a 2.0MM nozzle and will work just fine for you. Also remember to spray at 70 degrees if possible. The glue sprays much better when it's warmer.
Old 01-10-2009, 12:38 PM
Last journal entry: Bringing home the 401 Nailhead
I haven't tried it yet but others have suggested the $20 siphon feed that Harbor Freight sells. A search for "contact spray adhesives" returned this quote from DanTwoLAkes:
"The foam bonded to the velour fabric is an open cell polyurethane foam. Your best bet is to use a high temp spray grade contact adhesive like DAP Weldwood top and trim adhesive, 3-M Top and trim adhesive, or Helmitin Helmiprene, even if you have to spray or brush it on for a headliner. There is also a product called K-Grip 202 High Temp. All of those are best if sprayed. If I were you, I would invest in a cheap spray gun from Harbor Freight with at least a 2MM nozzle (They only cost about $20. Part # is 43760-6RBA) and use one of the bulk adhesives.
Do not use 3-M 74 or 77. They are general purpose adhesives and will fail if used on your headliner.
DAP makes an aerosol called Weldwood top and trim spray, and 3-M makes 08090 Super Trim adhesive. There is also a spray called Performance High Temp contact adhesive. All of those are your next best bet, but they are not really recommended for foam backed headliners. Good luck."
Old 01-31-2009, 08:56 PM
tc33's Avatar
Stuck in the 30's
Last journal entry: Where it came from and how I got there - a short Summary
My two cents...
I have used 3-M super trim adhesive (80 & 88) for door panels, side panels and anything vertical. Heat doesn't seem to bother it. I agree with Dan that it won't hold on the overhead stuff.
Old 01-31-2009, 09:11 PM
whinny's Avatar
66 mustang
ados f2 aerosol
you guys get that product over there, we use a lot of it down under!
Russ
Installing Stainless Steal Drip Rail Trim 65comet Body - Exterior 0 10-28-2008 09:52 PM
custom exterior trim impache Body - Exterior 0 10-09-2007 11:52 PM
Street Legal TV to Broadcast Video from NMCA Super Bowl Event at Route 66 nmrajames Hotrodders' Lounge 0 07-26-2006 10:53 PM
Super 40 vs 50 Series Delta Flow dannimo Engine 3 01-27-2004 04:16 PM
3M super 77 spray? nova33 Interior 5 08-17-2003 12:40 AM
