3rd brake light - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2002, 01:50 PM
Post 3rd brake light
I have a '99 Mustang. The top of my 3rd brake light is weathered. Where can I replace/upgrade it?
nyrrod@bellsouth.net :
Old 09-16-2002, 02:15 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Do you mean its faded? I havn't had the pleasure of seeing the interior of a new mustang, but if its plastic coverd you can get a can of spray interior dye the same color and spray it on and it will be good as new. If its not faded to get a replacement look in a salvage yard or your local ford dealer. Or you could just buy a trick billett LED 3rd brake light and replace it.
HK
Old 09-17-2002, 02:23 PM
Post
Thanks HK,
It is the stock 3rd brake light on a 99 mustang that is built into the trunk lid. I should be able to replace it from Ford, but I would like to upgrade to one which the top was not plastic.
Rod
3rd Brake Light Hook-up 39chevy Electrical 1 05-13-2006 03:12 PM
break light on..now what!? mrobby440 Suspension - Brakes - Steering 9 05-01-2006 01:30 AM
greased f. wheel bearings on 72 camaro, now brake light stays on bullheimer Suspension - Brakes - Steering 3 04-06-2006 10:43 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
Installing a 3rd brake light on a tinted window Jag Daddy Body - Exterior 3 05-30-2003 06:07 PM
