3rd gen camaro rearend advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2006, 09:15 PM
WV hillbilly
Last journal entry: PTL 220CC
hey, Have a 3rd gen camaro Im thinking about building, and the rear end is junk, I do have a 10 bolt from a 74 nova, factory v8 car, that is built with all new parts, what would I need to do to adapt it into the camaro?
thanks, 2wld4u
Old 06-18-2006, 09:12 PM
illuminatus
if i recall correctly, third generation and newer camaros were the first to use a torque arm setup so you'd need to fabricate a torque arm mount on your nova rear end (which is easier said than done) or drastically change the suspension setup (like backhalving the car and running ladder bars)
Old 06-19-2006, 01:35 PM
WV hillbilly
Originally Posted by ze doktor
if i recall correctly, third generation and newer camaros were the first to use a torque are setup so you'd need to fabricate a torque arm mount on your nova rear end (which is easier said than done) or drastically change the suspension setup (like backhalving the car and running ladder bars)
thanks, looks like I'll go ahead and start thinking 9" and yes, backhalving the car seems more practical, thats what I'll do..
2wld4u
SS Camaro starting in 3rd gear lostinthought Transmission - Rearend 5 02-11-2006 10:27 AM
Header clearence on 3rd gen camaros Cole32 Engine 1 01-27-2006 01:07 PM
New 5th Gen Camaro! BringBackTheCamaro Hotrodders' Lounge 1 01-20-2006 12:31 AM
69' Camaro - Need Wiper Motor Replacement Advice PrimaDude Engine 2 10-29-2005 07:08 AM
Anyone have a pic of a yellow 3rd gen camaro? stonedchihuahua Body - Exterior 5 12-17-2002 11:18 PM
