3spd columne shift to 4 spd - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2005, 06:01 PM
its not my fault
can a 3 spd columshift be converted to use a GM 4 spd? does anyone know a kit.
Old 03-26-2005, 06:49 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
good question, BUT if u can find one the late 60's chevy vans had a 4spd on the column but they are rare. i do know of one in Canada that's in a van being parted out....joe
Old 03-26-2005, 07:02 PM
its not my fault
ask him how much he wants? then maybe my people can get in touch with your people.
Old 03-27-2005, 08:34 PM
Max Keith's Avatar
4 spd on the column
Yes it can be done, but then you still have to have a way to shift into Reverse, as it will be outside the H pattern. Better off to drop a 4 spd shifter into it.
Old 03-29-2005, 12:13 AM
packratwrecker's Avatar
Too many hobbies!
If you want to make people ask a lot of questions, keep your forward gears on the column shift, and run a solenoid, or linear actuator, for reverse. Then mount a 2-speed switch on the shift lever. That'll keep 'em guessing.
I love sick & wrong. The look on people's faces are priceless.
Old 03-29-2005, 07:01 PM
I was thinking of putting a 4-speed in my pickup, and using a junkyard automatic floor shifter for reverse. An old overdrive cable might be adaptable, or maybe even a choke cable. Mark the knob "Ejection Seat".
By the way, engaging reverse and any forward gear (both at the same time) makes a pretty decent parking brake.
Old 03-31-2005, 11:42 PM
Too many hobbies!
Just don't forget to clutch before you start, or you'll blow the nose cone off your starter. Just like having a cylinder hydro-locked.
700r4 won't shift at WOT Alex99 Transmission - Rearend 39 02-15-2005 09:08 PM
Stall wrong, transmission shift adjustment, suggestions? frankenvette Transmission - Rearend 3 10-26-2004 11:59 AM
how does 700r know when to shift? manoso Transmission - Rearend 4 05-22-2004 11:20 AM
Swapping A 3 Spd 72 Gm Saginaw From A P/u To 4 Spd Saginaw From A 68 Camaro GMC72NV Transmission - Rearend 0 11-10-2003 02:51 PM
Tranny shift problems. chevcamz28newbie Transmission - Rearend 6 08-09-2003 05:52 PM
