4.0 L Ford SOHC cam timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2006, 07:22 PM
4.0 L Ford no timing marks???
May have messed in my hat, pulled the heads off my 4.0 Ford to replace head gaskets and found that the brilliant engineers forgot to include timing marks on any gears. Ford says I need a 500.00 cam aligning tool to reset the cams. Is there any way to get around it? HELP Thanks
Old 07-15-2006, 02:58 AM
aka Duke of URL
...ouch...
-4.0L CAM POSITIONING KIT-
Just a reminder, OTC makes FORD SPECIAL SERVICE TOOLS and often offers the same tools through their OTC BRAND which saves you big bucks.
Old 08-22-2011, 10:25 PM
seniormaster's Avatar
idea
talk to a local parts store, they may be able to get you the tools to line them up. i'm a ford tech and the kit can be found for under 300.00 at times.
Old 08-23-2011, 04:52 PM
LATECH's Avatar
It would be your best bet to take it to the blue oval store and get it done.
BBC Timing Top Rod Hotrodders' Lounge 4 11-13-2007 10:48 AM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 11:29 AM
Cam timing Dans83Olds Engine 2 06-07-2003 05:32 PM
4.6 Ford timing pontiac man Engine 1 01-22-2003 02:53 AM
BBC Timing Top Rod Engine 0 06-09-2002 08:29 AM
