Thread Tools Search this Thread share on Facebook
  #1
Old 01-16-2012, 05:48 PM
36 Chevy Guy 36 Chevy Guy is offline
4.0L main bearing seal replacement
4.0L in Ford Explorer Sprot Trac, how hard is it to replace the Main Bearing Seal. I know about pulling engine and Trans, anyother hidden problems.
Register now (free) or login to remove ads
Old 01-16-2012, 06:08 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
Once you get the trans un-hooked from the engine you will need to remove the flywheel/flexible to view the rear of the block, and you should invest is a seal puller and installer to get the job done properly. Not necessary but really makes the job alittle better. At least get the puller you can put it back in with something else .IMHO Don't think i left anything out but if i did maybe someone else will chime in to help.
Cole
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "4.0L main bearing seal replacement"
ThreadThread StarterForumRepliesLast Post
2 piece rear main seal replacementsouthshore30Engine1101-18-2010 03:34 PM
'57 283c.i. w/ rear rope main seal,is there a modern replacement??ssbuscemiEngine409-12-2007 04:48 PM
front seal/ rear main seal...helpmrobby440Engine205-11-2006 05:31 PM
fe main bearingjames dielEngine701-27-2006 04:57 PM
Main Bearing replacement?my350camaro84Engine007-24-2005 11:30 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
