4 1/2" Bolt pattern rims - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2003, 07:08 PM
Seon's Avatar
I just bought trailer axles with hubs that has 4 1/2" x 5 bolt pattern. I''ll need to get rims and tires. What make/model car uses this bolt pattern? Thanks
Old 06-11-2003, 09:06 PM
stea's Avatar
most ford passanger i believe, i know the mustangs and the cougars use that pattern
Old 06-11-2003, 10:39 PM
Pontiac Knowledge Base Editor
Ford Ranger, Bronco II, and Explorer.
Dodge, any older RWD cars.
And older Toyota Trucks with 5 bolt pattern
Old 06-12-2003, 07:57 AM
Seon's Avatar
Thanks for the replies. I'll check the swap meets for rims and tires.
Old 06-13-2003, 06:34 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Everyone always forgets AMC! AMC, FoMoCo, and most Chryco rear drive cars use 4.5x5 bolt pattern wheels. Small Jeeps use them, but they are usually deep offset. Stay away from Ford and Chevy small 4x4 wheels also -- they have deep offsets too. And then Toyota big cars and trucks use the same pattern, and I think one or two other Japanese larger cars (likes the old Toyota Crown and Cressida, if they have the five lug wheels).
Old 06-13-2003, 07:17 AM
Seon's Avatar
Thanks for this additional info. I'll go to the bone yard and look if I can't find them in a swap meet.
Old 06-14-2003, 08:16 PM
Seon, you probably already know this, but take a quick measure of your hub flange where the center hole fits. It's embarrassing to find the 4.5X5 rims, mount and balance your tires and then find out the wheel will not go on because the center hole is too small. Bet I'm the only guy to ever do that!?
Trees
Old 06-15-2003, 07:32 AM
Seon's Avatar
Good point. Thanks for the heads up.
Old 06-17-2003, 07:36 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Trees
Yes that is a totally stupid mistake. I would NEVER make that mistake. I make my OWN stupid mistakes!:laugh: :laugh:
Old 06-21-2003, 08:21 PM
Many of the high performance imports use that bolt pattern most aftermarket companies make wheels in that pattern in any size/offset you could want
Old 06-21-2003, 09:03 PM
4.5"x5 wheels
Dodge 1/2 ton Pickups 1975-1979 I have 4 or 5 of them 15"x8"
Old 01-05-2004, 03:36 PM
New Member
4.5 TIMES 5 LUGS
THE OLDER FORD LARGE PASS CARS-60s ETC USED THIS PATTERN ALSO 70s-RANCHEROS-MID 80s-TOYOTA P.U.--THE TOYOTA CRESSIDA HAS FOUR LUG WHEELS- GOOD LUCK.
Old 01-05-2004, 03:50 PM
Last journal entry: Rear End Disassembly
a lot of chrysler, plymouth, dodge used this bolt pattern. Depends if the car was a high end car or not, otherwise they would use 5x4". I have some 5x4.5" rims for sale if you have any interst, they were on my 71 plymouth. they are 14's, 14x9 i belive in the rear and 14x7 in front. Couldn't find a tire dealer in the area who could fit that rear tire, so I got new 15" rims. let me know.
Old 08-06-2006, 09:31 PM
73 Nova Steel's Avatar
73 Nova Steel
I know for a fact that if you can find a 1973 Chevy Nova, you will indeed find 5 on 4 1/2 bolt patern rims unless of course they were changed and by changed im talkin hubs and axels as well. Dave
Old 08-06-2006, 10:01 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
WRONGGGGGG, they use a 5x4 3/4 bolt pattern & this is the correct way to measure them...joe
