Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 12-30-2005, 07:37 PM
elsanyo elsanyo is offline
4.11 or 4.30
ok here we go ,I have a 1984 f 150,yea its a brick but its got a 357 with a c6 and a 2800 stall converter . my question is should I go to the4.30 gears or stay with the4.11
Old 12-30-2005, 07:39 PM
Bumpstick's Avatar
Bumpstick Bumpstick is offline
Hammer and a torch
re: 4.11 or 4.30
From 4.11 to 4.30 is not much unless its an all out drag setup... Moving to a 4.56 or lower gear would help move the "brick" (I run a 4.56 in my 69 C10)
Old 12-30-2005, 07:59 PM
re: 4.11 or 4.30
going to 4.56 is quite a jump ,I don't think that that would be good for me since I do drive it some distances to shows and cruiseins
Old 12-30-2005, 08:23 PM
Bumpstick's Avatar
Hammer and a torch
re: 4.11 or 4.30
I would stick with the 4.11 in that case... No real gain with the 4.30
Old 01-04-2006, 07:33 PM
re: 4.11 or 4.30
bumpstick ,4.56 and 30" tires shouldn't be to bad I guess .I was running 4.11 and 27.5 " tires and was turning around 2800 @ 55. So if I stay off the hyways I should be ok right?I just want more out of the hole and shortin my 60' time. I've gota kid at work that needs an attitude adjustment,you know the type new dodge with a HEMI It's a frikkin 4 door turd but he thinks its hot. My best times have been in the 14's gota get better.
Old 01-04-2006, 07:57 PM
Bumpstick's Avatar
Hammer and a torch
re: 4.11 or 4.30
With my 4.56 gear and a pair of 28.5 tall tires it does 55 @3000K rpm and according to the calculators it would need 3550rpm to make 65mph...
You could use the 30" tall tires and the 4.56 and keep a pair of 28`ish tall slicks just to cause him heart failure off the line...
Old 01-05-2006, 01:27 PM
larryblack's Avatar
larryblack larryblack is offline
Certified Lead Foot
Location: Red Stick, Cajun Land, The Dome, TX and I-10 in between.
re: 4.11 or 4.30
That thing has 3.9 gears. They tend to be stump pullers. I have talked to a couple owners and both had tow rigs prior and both said the dodge out pulls the old rig. One had a Chev and the other had been a ford.
BTW, if it has the HEMI decal on the bed panels that is worth at least 100 mental horsepower.
Old 01-06-2006, 01:26 PM
Siggy_Freud's Avatar
Siggy_Freud Siggy_Freud is offline
FI Young Gunner - Moderator
 Siggy_Freud's barnstar
re: 4.11 or 4.30
Dont knock the Hemi's too much. They had 4.10 gears as an option in those trucks as well. With a few aftermarket modification those trucks can be made to run very hard.
The amount of worry you should have will depend on the options his truck has (like 2wd vs 4wd, long bed, vs short, etc). A person I know and have raced with ran a 14 flat at the track with his Rumble Bee model. I believe both those and the Daytona models come with very steep gearing.
My opinion . . . it should be a good race.
1997 BMW M3 - 3.2litre Inline 6 cylinder
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "4.11 or 4.30"
4.11 or 4.30 elsanyo Introduce Yourself 2 12-30-2005 10:38 PM
beef up my 289 2v 67stangnut Engine 91 12-27-2004 07:12 AM
4.11 gears??? 71gtx Transmission - Rearend 10 09-11-2003 10:59 AM
4.11 on my 1978 LWR100 Transmission - Rearend 1 03-31-2003 02:02 PM
