4.127" bore which pistons? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2013, 04:54 PM
Hello everbody,
I bought a very nice Dart SHP block from ebay. As the bore has been torqueplate honed to 4.127" for the previous pistons I'm wondering what piston diameters I can just for this bore? Do I only choose from pistons with a advertised 4.127" bore or also 4.125" etc etc? As this is going to be a high compression engine I want it to be in the ballpark with everything so I'm not going to cut corners.
Thanks!
Greetings Peter
Old 05-03-2013, 05:24 PM
vinniekq2's Avatar
what engine are you building?The piston manufacturers may have what you want in stock.You may still have to hand fit them,,,
Old 05-03-2013, 06:27 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Dial bore measure it in multi locations and all the bores,Wisco will made anything you want.Tell them what you measured and what you have/want.
Old 05-06-2013, 11:03 AM
Thank you, as I already have a dail bore gauge I'll check every bore on 3 locations so I can email the measures to some manufacturers.
I'll just start a new topic on this subject as I have some other questions
Greetings Peter
Old 05-06-2013, 11:31 AM
Originally Posted by Peer81 View Post
Hello everbody,
Thanks!
Greetings Peter
If the bore is in finished condition; that is finish honed and ready for assembly and measures a true 4.127 inches, then you would need to provide an operating clearance, a 4.125 piston would furnish a .002 inch clearance which is in the ball park but on the tight side. This would require a high silicon piston that is more thermally stable whether hyper-eutectic cast or 4032 forged, even then this would be a street clearance. For a hard woking engine, race or industrial you'd want to rehone the block to open up the bore another .001 to .0015 inch with the 4.125 piston.
Bogie
The Following 2 Users Say Thank You to oldbogie For This Useful Post:
AutoGear (05-07-2013), techinspector1 (05-06-2013)
Old 05-06-2013, 04:58 PM
techinspector1's Avatar
Wiki Edits: 326
Here's a chart from Keith Black pistons backing up what oldbogie says about a KB hypereutectic (high silicon, cast) piston.....
http://www.kb-silvolite.com/assets/kb_installation.pdf
By the way, if any of you guys want to learn about pistons and rings, this is a good source for quality information.....
http://www.kb-silvolite.com/features.php
http://www.kb-silvolite.com/news.php
http://www.kb-silvolite.com/article.php
can you bore a 283 block out to a 4" bore ? Mustangsaly Engine 13 05-01-2007 04:02 PM
engine bore and pistons jerry1 Engine 4 11-25-2006 08:27 PM
anyone ever able to fit 3.76 bore pistons in a 3.5 bore engine? 74chevyflat Engine 15 05-21-2006 08:58 PM
Which Bore And Pistons? Ford 302 nightrain_rod Engine 36 12-08-2003 12:45 AM
Can you use .030"pistons in .035" bore? shockers69 Engine 34 11-17-2003 03:37 PM
