Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 06-05-2006, 08:54 PM
EastCoastSBC's Avatar
EastCoastSBC EastCoastSBC is offline
Don't worry I'm a Professional
4 to 2 door conversion
I have a question regarding door conversions. Lets use a 57 bel air. I bought a 57 Bel Air 210 4 door and want to convert it to a 2 door whats involved? What parts will I need? Where do i get them?
Old 06-05-2006, 09:48 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is online now
oddroddermodderate-tor
 powerrodsmike's barnstar
Wiki Edits: 126
re: 4 to 2 door conversion
Ok I see you are a professional (its in your avatar) so here is what I know:
4 door to 2 door conversions are a hella alota of work to do right. IF, if they are worth being done at all.
Doors are longer on a 2 door so if you want to not have it look funny you get to :
get the long doors,
get 2 door quarter panels,
get 2 door glass, trim and interior.
Move the "B" pillar. I think the roofline at the driprail is
different on that chevy so you get to modify that. Install all of your 2 door parts. spend eternity doing bodywork
That's all there is to it
OR, weld up the 2 rear doors and have a "short door" sedan.
hope this helps, mikey
(you didn't buy this car yet did you?)
BE different....ACT normal.
Old 06-05-2006, 11:04 PM
MARTINSR MARTINSR is offline
I'm with Mike, you would need to have a two door parts car to pull it off. At that rate, you might as well part out the four door to build the two door body.
I would do this before I tried to make it a "real" two door.
Old 06-06-2006, 10:05 AM
thanks and no powerrodsmike it was just a what if question cause a 4 door is a grandma's car
Plus this will all become easier next year i get told this week (friday) if i am going to go to tech school part time for auto body. The great part is that i dont have to take science because autobody counts as a science.
Old 06-06-2006, 04:32 PM
redsdad redsdad is offline
Will I ever get it done?
You might be better off converting it into a convertible.
http://www.danchuk.com/12_02_full_doors.html#4119
http://www.danchuk.com/03_03_conv_x..._assy.html#3113
http://www.danchuk.com/03_06_conv_t..._assy.html#2571
http://www.danchuk.com/13_02_upper_..._fram.html#2522
Plus the 100 or so other parts you need to convert one. When you are done, however, you have a very desirable car.
Old 06-06-2006, 06:32 PM
Qtrmeg Qtrmeg is offline
Ya, next year you will be all set.
Foose changed a 56 4 dr to a 2 dr on the first year of Overhaulin. I couldn't believe he did it, nevermind in a week.
Say what you want, but that shows you can do anything you put your mind to. I deal with reality, and my skills and budget dictate what I can do, but don't ever stop dreaming kid.
Old 06-09-2006, 08:11 PM
Well they told me to day i was accepted to votech
Old 06-09-2006, 08:17 PM
Wiki Edits: 126
Yeah Buddy!
Mikey
Old 06-09-2006, 08:32 PM
cboy's Avatar
cboy cboy is offline
Always Learning - Moderator
 cboy's barnstar
I "converted" this 4-door in the early 90's. I simply welded up the rear doors and then used a set of Honda bucket seats so you could squeeze into the back seat. I wouldn't do this with any sort of pristine car but this one was not in that great of shape so I had a little fun with it.
Old 06-09-2006, 09:16 PM
TooMany2count's Avatar
TooMany2count TooMany2count is offline
A Half Crippled Old SOB....
 TooMany2count's barnstar
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
1st TECH TIP .... 2nd Post on the HAMB about making a 4dr into a 2 door & from looking at it, it's fairly simple if u know anything about body work. if nothing else go to Hamb, be sure to do an intro & then ask some questions....joe
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
