4.3 to 5.7 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2004, 08:20 PM
4.3 to 5.7
will the accesories off of a '91 4.3 bolt on to a 5.7? This particular 4.3 is a serpentine with a/c. does it matter if the 5.7 is pre or post '87? Thanks!
Old 09-30-2004, 08:52 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
How about a little more info.
Car? Year? Year of 5.7?
Not to be rude, but give specifics if you want an answer.
Old 09-30-2004, 09:49 PM
sorry about that. I'm wondering if i can use my original 4.3's accessories on a 350 to swap into my 91 sonoma. I plan on using a late model longblock from a full size gm truck.
Old 10-01-2004, 04:50 PM
NorthStar's Avatar
The early style heads with perimeter bolt valve cover and newer center bolt valve cover heads have different bolt spacing for the accessory bolt holes.
There is a small difference that was made to the Vortec engine blocks, they dont have a hole for the water pump bypass like the older blocks do. The bypass comes out of the water pump and is plumbed to intake with rubber hose kind of like a big block Chevy.
So as long as your "new" 350 has centerbolt valve covers and the block is pre 1996. All the stuff will bolt up to the heads and existing water pump will work just fine.
If the block is 1996 & newer it could be used too but you would have to drill some little holes in thermostat. Also the 1996 & up Vortec engines have a roller cam so would be a good reason to use it.
You can keep the 350 damper the pulley will bolt right on.
Cant really think of anything else.
Old 10-01-2004, 06:34 PM
wow, thats great. This 350 swap is looking easier and easier. I thought that 87-95 SBC's were roller hydraulic cams though, or is that just LT1's and LT4's?
Old 10-01-2004, 06:52 PM
Almost an old guy...
I just finished a swap with a 355 into my 91 S-15 Jimmy, I think you may find that you will have some major clearance issues using the 4.3 setup in the swap, not enough room for the fan...
Old 10-01-2004, 08:47 PM
My plan is to move the radiator and AC condensor forward 1-2 inches and run an electric fan. (this truck runs plenty cold now and isn't used for towing, and i live in new england, so I dont anticipate any overheating problems.) I also am going to hammer the firewall a little (according to the JTR hand book) and set the engine a half inch to 3/4inch rear. I will use the setback plate on the axle. Seems like it will work in theory. Anyone see any flaws?
Old 10-01-2004, 08:53 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Will you have any problems with emissions testing?
Old 10-01-2004, 08:56 PM
Yes, I want it to be emissions legal as it will be my daily driver.
Old 10-02-2004, 05:03 AM
With the electric fan and moving the rad forward you shouldn't have any clearance issues. Get one really big hammer for that firewall, mine was hell to pound in and could have used a little more on the passengers side for the hedder collector...
