4.3 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2010, 04:44 PM
Hello my son has a 4.3 that he is trying to put in place of a 350 it is a 1989 gmc truck will he have to change the motor mount bracket on the truck and if so what does he need to do. Thanks
Old 09-06-2010, 06:38 AM
sedan delivery's Avatar
motor mounts
there is a article on Rodster.com about swapping a V6 for a V8. they use the same mount for the v8 as as used for the v6. check this article
http://www.rodster.com/articles/article14.htm
Old 09-06-2010, 07:11 AM
Hippie's Avatar
Last journal entry: HEI comparison.
The mounts themselves are the same but the frame brackets are different. The mount bosses on the 4.3 block are positioned farther back on the 4.3 than on the V-8's. I was going to go the opposite direction on an '89 a few years back. Check the truck boards, you nmight be able to find someone doing the V-6 to V-8 swap that will trade you brackets ot that has just done it and wil make you a deal. They should be easy to find in the salvage yards that don't use a torch too, most guys want the V-8 brackets.
Old 09-06-2010, 01:32 PM
FastOrange's Avatar
you will need to change the frame AND engine mounts to the 4.3L ones, you will need to use a 4.3L TBI unit, Shroud for rad needs to be changed, and you should get a tune for the computer but a STOCK TBI 4.3L will run fine on a 350 tune.
Also, you should get a 4.3L torque convertor.
Old 09-06-2010, 02:36 PM
Hippie's Avatar
When I was rounding up parts for my swap the parts book I checked said mounts were the same. I take it the book was wrong? Good call on the other stuff......
Old 09-06-2010, 04:36 PM
FastOrange's Avatar
i went from a 4.3L to a 350 in my 1994. the 4.3L actualley had opposite mounts, Clam-shells on the frame, rubber mounts on the block.
FastOrange's Avatar
but with that being said, things could have changed between 1988-1994.
4.3 V-6 with LT-1 TPI? 77'Omega Engine 17 07-05-2010 05:48 PM
swapping injectors 2003 4.3 rcrge Engine 1 05-08-2009 06:56 AM
4.3 to 5.7 swap th400 -transmission braces daveEM Transmission - Rearend 6 07-05-2008 06:49 AM
4.3 tbi and 4.3 vortech... same crank ???? marb6 Engine 3 10-15-2006 11:36 AM
4.3 to 5.7 s-10 manny tranny MartyMart9@aol.com Transmission - Rearend 2 11-03-2003 07:58 PM
