4.3 cam sensor repeated failure - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2013, 01:39 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
My buddy Bill is looking at a 2003 Chevy S-10 4x4 with the 4.3 V/6 for possible purchase. Problem is the current owner said that he has had to replace the cam sensor three (3) times.
What would cause a cam sensor to fail repeatedly in a 4.3 V/6 ?
Bill is not going to buy this truck without knowing why this would keep happening. Truck just had a $1500.oo paint job and spray in bed liner, and is for sale for $2200.oo. Good deal if we can get the cam sensor problem straightened out.
Thanks, Allan
Old 09-18-2013, 05:15 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Aftermarket electronic parts pretty much suck. Its the luck of the draw with a lot of them. I could give a long list of "new" aftermarket electronic parts that didnt work right out of the box. Its mind boggling.
Get a new one from the general and put it in.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
adantessr (09-18-2013)
Old 09-18-2013, 05:18 PM
LATECH's Avatar
Ask him why he says it keeps "eating" cam sensors. If he says it keeps setting a P1345 trouble code...chances are the sensor isnt the problem.
A worn dizzy gear is usually the culprit and a simple cam/crank sensor correlation/learn is all that is needed once a new gear is installed.
Repeated starter failure, now the flywheel. DaSouthWon Engine 9 12-31-2008 11:34 AM
New cam failure, how long before you know? 4speed57 Engine 15 07-26-2008 01:39 PM
Cam failure and oils JPhil Engine 0 03-12-2006 12:17 PM
Cam failure ? bowtieorbust Engine 13 07-23-2004 08:03 PM
roller cam failure? 68chevelle_ss Engine 8 11-17-2003 04:25 PM
