-   -   4.3 chev v-6 (http://www.hotrodders.com/forum/4-3-chev-v-6-a-210521.html)
ratrodrick 12-17-2011 10:39 PM
4.3 chev v-6
i am looking for a 4 barrell manifold for a 4.3 chev v-6 circa 1995,also mild cam and roller rockers for same.don't be to hard on me i'm an old timer needing projects.
DoubleVision 12-17-2011 11:06 PM
First off you have to make sure of the year as many changes were made over the years. Some had balance shafts, some didn`t. Also by `95 some had non adjustable rockers and others had adjustable rockers.
Read this link, it`ll teach you alot.
http://www.s10forum.com/forum/f107/t...3-info-131868/
cobalt327 12-18-2011 03:53 AM
I don't know if they will consider your post a classified ad or what, but there's a free Classifieds section you can use to look for parts.
The choices are marine intakes (which I know nothing about), the Q-jet OEM cast iron intake (used briefly through '86 when TBI began being used across the board), or a new Edelbrock #2111 (about $290 plus shipping). The Eddy p/n 2114 is for the '96-up Vortec heads, it is a different intake and won't work w/the older style heads.
On eBay the OEM cast iron intakes fetch $100-up (I bought an entire '86 4.3L w/carb, intake, distributor, etc. for less than that, locally). The Edelbrock used on eBay costs considerably more. Holley used to make an aluminum intake for the V6, it gets upwards of $200 when you see one on eBay.
You might luck into an OEM cast iron intake for the 4.3L on craigslist for cheap if they don't know what they're worth. One last option is the OEM aluminum 2 barrel intake like was used on the 200/229 Chevy 90 degree V6. These intakes are relatively cheap and carbs aren't hard to find. It would get you on the road, at least. It uses the Rochester Dualjet carb, shown below.
If you had TBI, you will also need a 4.3L distributor w/vacuum and mechanical advance.
https://encrypted-tbn0.google.com/im...RpTL5Ne9hMQdCQ
SDLuck 12-18-2011 10:23 AM
I was told that the 4.3 was used in boats and had a 4 barrel intake.
SDLuck 12-18-2011 10:33 AM
4.3 V6 4 V B Intake Manifold OMC MerCruiser Chevy Volvo
Buy It Now $260.61 Time left:19d 3h 51m
matts37chev 12-18-2011 12:27 PM
here are some intakes
I dont know if they will work for your exact application, or are what you are looking for
