Thread Tools Search this Thread share on Facebook
  #1
Old 12-17-2011, 10:39 PM
ratrodrick ratrodrick is offline
4.3 chev v-6
i am looking for a 4 barrell manifold for a 4.3 chev v-6 circa 1995,also mild cam and roller rockers for same.don't be to hard on me i'm an old timer needing projects.
Register now (free) or login to remove ads
Old 12-17-2011, 11:06 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Socially Unsociable
First off you have to make sure of the year as many changes were made over the years. Some had balance shafts, some didn`t. Also by `95 some had non adjustable rockers and others had adjustable rockers.
Read this link, it`ll teach you alot.
http://www.s10forum.com/forum/f107/...-3-info-131868/
Old 12-18-2011, 03:53 AM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
I don't know if they will consider your post a classified ad or what, but there's a free Classifieds section you can use to look for parts.
The choices are marine intakes (which I know nothing about), the Q-jet OEM cast iron intake (used briefly through '86 when TBI began being used across the board), or a new Edelbrock #2111 (about $290 plus shipping). The Eddy p/n 2114 is for the '96-up Vortec heads, it is a different intake and won't work w/the older style heads.
On eBay the OEM cast iron intakes fetch $100-up (I bought an entire '86 4.3L w/carb, intake, distributor, etc. for less than that, locally). The Edelbrock used on eBay costs considerably more. Holley used to make an aluminum intake for the V6, it gets upwards of $200 when you see one on eBay.
You might luck into an OEM cast iron intake for the 4.3L on craigslist for cheap if they don't know what they're worth. One last option is the OEM aluminum 2 barrel intake like was used on the 200/229 Chevy 90 degree V6. These intakes are relatively cheap and carbs aren't hard to find. It would get you on the road, at least. It uses the Rochester Dualjet carb, shown below.
If you had TBI, you will also need a 4.3L distributor w/vacuum and mechanical advance.
Old 12-18-2011, 10:23 AM
SDLuck SDLuck is online now
I was told that the 4.3 was used in boats and had a 4 barrel intake.
Old 12-18-2011, 10:33 AM
4.3 V6 4 V B Intake Manifold OMC MerCruiser Chevy Volvo
Buy It Now $260.61 Time left:19d 3h 51m
Old 12-18-2011, 12:27 PM
matts37chev's Avatar
matts37chev matts37chev is offline
I don't understand?
Last journal entry: the LH sides' turn for more rust removal
Last classified ad: 1937 chevy stock 6cyl...
here are some intakes
I dont know if they will work for your exact application, or are what you are looking for
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "4.3 chev v-6"
ThreadThread StarterForumRepliesLast Post
Early Chev/oller Cam Chev DifferencesbelairheavenEngine108-14-2010 08:31 AM
Early Chev/roller Cam Chev DifferencesbelairheavenEngine408-14-2010 05:59 AM
Big chev 454 and small chev 350 bolt patternboneyard BuickEngine401-18-2006 09:07 PM
Has anybody used a Chev Astro van booster/master cylinder for the 48 chev trucktomy2tone01Suspension - Brakes - Steering204-07-2003 05:05 PM
Installing a chev small block in the rear of an chev s-10vegadethBody - Exterior1107-16-2002 03:16 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
