4.3 chevy install into Suzuki XL7 2002 ... problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2013, 09:16 PM
Hi, friends I have a suzuki XL7 2002 and the engine died and i installed a 4.3 Chevy Astro BTI of 1993 I have all the wiring and the computer but I have doubts as to give it power, if someone can help me, thanks a lot!
BTW, exscuse my english i use a translate program!
Old 04-06-2013, 09:53 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The english is fine. Where are you from?
I checked some of my books on this and have this to recommend.
You need to have the schematic wiring diagrams for the vehicle and the engine donor vehicle.
For example the PCM will require a (hot-at-all-times) fused feed. The PCM will also require an ignition ON fused feed.
The PCM will control a relay that is the fuel system pump prime when the ignition is first turned ON. An oil pressure switch on the engine will maintain the fuel pump running.
Without the schematics you are guessing and wasting time and possibly damage could result.
One source for the schematics is ALLDATAdiy.com Leading Source of Factory Automotive Repair Information.
vicrod
4.3 Chevy V6 in a Suzuki Samurai speedydeedy General Rodding Tech 12 08-24-2015 07:57 PM
2002 S-10 transmission problems shee4202 Transmission - Rearend 9 08-16-2012 02:07 PM
2002 S-10 tranny problems?? bamafan Transmission - Rearend 1 02-23-2011 05:54 PM
2002 zr2 overheating problems. SonnyFaust Engine 5 08-19-2010 10:58 AM
1954 Chevy Pickup and a 2002 Camaro Subframe install?? eirhed Suspension - Brakes - Steering 2 09-05-2007 03:36 PM
