4.3 Chevy Marine Engine Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2010, 08:38 PM
oldcpecdr's Avatar
Hey all
Friend has a 4.3 "Volvo" Marine Engine that turns out to be a CHEVY!!!! So she let it freeze last year and is getting what I think are ridiculous prices on fixing it. If I use her accessories and get a marine cam any reason I cant just rebuild a 4.3 short block for her ? Other than the exhaust manifolds and water pump and other bolt ons I cant see a lot of difference...
Thanks for your advice... Mike B
Old 09-30-2010, 08:53 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I don't see why not, I have a 5.7 Mercruiser. Be sure to use spark arrester starter, alternator, air cleaner.
Semper Fi
Old 09-30-2010, 09:16 PM
techinspector1's Avatar
Wiki Edits: 326
Make sure which way the crank turns. Some marine applications are reverse rotation. Standard rotation is clockwise looking at the front of the crank, counter-clockwise looking at the flywheel. Reverse rotation cams and distributors are available.
Old 10-01-2010, 01:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by oldcpecdr
Hey all
Unless it's an old engine, it'll have a roller cam- you can reuse it and everything else that's in or on that engine, on another block or short block.
The marine heads should be reused if they weren't hurt in the freeze- sometimes they have heavy duty exhaust seats. I would also check to see what the ring gap recommendations are for a marine engine just in case that differs from automotive use engines.
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Question on 2003 Chevy Suburban 5.3 Engine bry21317 Engine 11 09-18-2008 04:04 PM
Update on previous Marine Engine question bigjoedo Engine 0 07-08-2003 12:52 PM
Hotrodders Guidelines -- READ ME Jon Transmission - Rearend 0 06-14-2003 04:58 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
