4.3 chevy v6 dist computer bypass help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2005, 10:35 PM
38 old coupe's Avatar
Last journal entry: Electric windows
i need to know how to bypass the computer to make the dist work i see some one spliced into 2 of the 4 wires but i just got the motor from a guy to put in his s10 blazer he wanted a carb instead of throttle body so can any one help please thank you
Old 08-02-2005, 02:29 PM
docvette's Avatar
Wiki Edits: 12
Dizzy
Doc here,
If your Not running ANYTHING else that requires a Computer...
Get a pre 1980 HEI V6 Dizzy from the Boneyard..with Vacuum/mechanical advance, and replace it with your current one.
If you have need of computer Support, you need to isolate that which requires spark timing and advance and modify for that...will require an accurate schematic.
Doc
Chevy 229 (3.8l) v6 Buildup Help!!! Timberwolf Engine 17 02-24-2014 08:30 AM
1991 chevy 4wd V6 swap to V8 Michael Breaux Engine 3 10-20-2002 02:48 PM
4.3 v6 CARGUY Engine 2 06-05-2002 06:17 PM
Chevy 4.3L V6 to 350 swap pitsen3 Engine 2 03-16-2002 09:22 AM
pontiac V6 to chevy V8 swap snake Engine 2 01-20-2002 03:58 PM
