4.3 Distributor computer to non computer - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2007, 04:00 PM
When doing away with the computer on a '94 vortec 4.3 engine, how can I still use the computerizied distrubutor? I was told that all that I needed was to keep the coil wire to the dist. module hooped up and forget the otherside of the module, then run a hot wire to the coil, set the timing to about 18deg. and fire it up and go. Will this work or not? It sounds a little screwy to me.
Old 04-18-2007, 05:02 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
It will run...
BUT have no performance..It will have no EST, which controls the timing advance/ retard..which is needed to "Keep up" with the changing demands of the engine.
You need to go to a pre 1980 GM HEI, or an aftermarket with advance features..(either vacuum or electronic, or mechanical) The pre 80's HEI is the cheapest route..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 04-18-2007, 08:51 PM
You need to use a "conventional" HEI distributor for the 4.3L V6. There are aftermarket units, or you can use a distributor from a 1985 Astrovan. They used a carb and conventional HEI. Do not use a 200-229 Chevy V6 distributor as they aren't even fire. The computer controlled unit won't work.
Bob
Old 04-18-2007, 09:15 PM
Thanks for the replies. but there is not enought room for the HEI. If I cannot get the orginal to work I will have to go aftermarket. The fellow who said it would work races his, he said he used about 36deg. advance for it. If that's true or not I do not know.
Doc, the 4.3 was not made before '80. The 229 and 231 will not work I am told. The early 4.3 dist. were big, like all the HEI's.
I have read some threads from a guy called Ignition Man. He seems to have done something with these but I don't know what. Thanks.
Old 04-18-2007, 10:27 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Oops ! My BAD!!! forgot about the 4.3 was a V6.. always thinking 8's..
Sorry about my wrong info..
MSD has some good solutions for this..go to their website and have a look at the product line..
ALSO, the guy your talking about is Dave's Small body HEI's in Nevada, just do a search under that and go to his site for what he provides..
Sorry for the confusion..
Doc
Innovations
Old 04-19-2007, 12:25 PM
Thanks Doc, I think he has the best route for me.
Old 04-19-2007, 05:37 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Your welcome
Let us know what you come up with.
Doc
Innovations
Help with computer with Linux/Lindows OS powerrodsmike Off-Topic 10 06-20-2006 03:41 AM
4.3 chevy v6 dist computer bypass help please 38 old coupe Electrical 1 08-02-2005 02:29 PM
Basic Computer Safety strikingthematch Hotrodders' Lounge 6 02-03-2005 04:12 AM
Smoked computer during start Chadman Engine 3 08-20-2003 12:12 PM
Fuel Injection Computer Big Mac Engine 0 12-04-2002 03:42 PM
