Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4.3 Has Me WHIPPED!
Old 11-29-2005, 07:34 PM
schnitz's Avatar
schnitz schnitz is offline
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Originally Posted by machine shop tom
SOMETHING caused those studs to pull out. My guess is the timing chain jumped and caused the valves to hit the pistons and that interference caused the studs to pull. Another thought is the valves were adjusted too tight by somebody and the valve springs bound up and pulled the studs. I would check the pushrods and see if any are bent.
I would agree and I'd be willing to bet that the springs aren't exactly stock tension either.
One thing I did notice was with the pushrods removed I tryed to push in on the lifters with a screwdriver.Only 2 collapsed about 1/4 inch.the other 4 were tight like a solid.
Sounds right on if the valves were adjusted too tight. And judging by the last post (if I remember the right way to set a 4.3), that would do it. But I may be wrong.
In a while, Chet.
