4.3 Liter V 6 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2002, 02:05 PM
Post 4.3 Liter V 6 problem
This problem is not on my Hot Rod its in my 88 GMC pickup. For years this thing throws a fit every now and then. It will stutter, backfire,almost stall ect. under hard accleration. I usuall fix it by tightning a bolt on the thermostat neck that has three wires on it. MY question is. What is the cause of this?
ED "Doity9"
Old 01-28-2002, 03:31 PM
Post
Sounds like the ignition module is trying to go bad(which is common after many hours of service), but normally the symptoms you described begin as a warning shot and not long after, it just goes completely out. It's a simple part that plugs into the distributor(inside of) and cost 'bout 40-60 dollars.
Old 01-28-2002, 04:45 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Post
Are those three wires possibly grounds? If so mabye through time they corrode a little bit and lose thier connection to ground and then you come along and tighten the bolt and the tightening force makes it ground again. Just an idea, it is hard to trouble shoot sometimes when you can"t look at it.
Old 01-28-2002, 08:19 PM
Post
Ed those wires are the ground wires for the computer system. That was really a dum place to put them. Take those wires and ground them some place else. Ground them to the engine like a bolt in the head or somewhere like that. Where they put them when I worked for GM we called that a brain fart.You might even have to make them longer. ROY
Old 01-31-2002, 03:25 PM
Post
I want to thank all you guys for your replys, I'll try and rerout those wires some place else. Just think of all those poor souls that got screwed by mechanics that sold them a bill of goods and all they did was clean and tighten those wires. ED
