4.3 motor came with my frame I want to swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2010, 08:26 PM
I have a 1991 S-10, 4x4 chevy rolling chassis, that was fitted w/ a 4.3 motor will any 283, 327 and 350 fit with the exact same engine mounts? TIA, Dana
Old 07-31-2010, 10:46 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Yes, but read the link
Rich
http://www.jagsthatrun.com/Pages/Par...entMounts.html
The stock S10 4.3 V6 engine mounts use large, soft rubber isolators to reduce engine vibrations that go into the cab of the S10 trucks. The soft rubber isolators are not well suited for performance applications because they allow too much engine movement, which can lead to problems with headers contacting the frame and the steering shaft, as well as axle hop problems.
Because the stock 4.3 V6 mounts are made from rubber bonded to steel, the mounts often fail, with the rubber tearing away from the steel, and allowing the engine to contact the hood. The fan can also contact the fan shroud, damaging the fan and shroud.
Stealth Conversion's high-performance 4.3 V6 mount assembly uses a Chevrolet 2.8 V6 S-10 replacement mount (part # S10-106), and the JTR 2.8 to 4.3 V6 conversion mount (part # S10-109).
The mount assembly is stiffer than the stock S10 4.3 V6 mounts, but is soft enough to be used on street driven vehicles without transmitting excessive noise and vibration into the truck. The 2.8 V6 replacement mount has the rubber surrounded by steel. This mount is the most common mount to use in the S-10 V8 swap -- it has proven itself to be strong enough for even the most powerful V8ís, yet compliant enough to prevent noise and vibration from entering the cab.
This kit will bolt directly into most S-10 trucks and Blazers with the 4.3 V6, using the original mounting holes on the S-10 frame, and on the 4.3 V6 engine. Note: This kit will not work on ZR2 trucks, and neither will the mounts.
Old 08-01-2010, 07:56 AM
BOBCRMAN@aol.com's Avatar
Will fit the engine/chassis with adapter plate. Oil pan will be a problem on some applications.
Old 08-01-2010, 08:01 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Those JTR/2.8 mount adapters look like something a kid in a welding class dreamed up as a class project. They aren't very strong, and DON'T work with long tube headers. Take a look at the TransDapt P/N 4689, same as the old Hooker V8 mount adapters. They use a standard V8 style frame mount, and regular old V8 motor mount shells. IMHO (as a V8 S10 guru, ), a MUCH better mounting system,
If you'd prefer to make your own, shoot me a P/M with your email addy, and I'll send you a pair of templates made from the very first Hooker mount adapters I used, back in '85. They are in .pdf format, so they will print the perfect size on any printer.
The Following User Says Thank You to Rickracer For This Useful Post:
drkustomz (02-10-2014)
Frame Swap help. rayzorsharp Hotrodding Basics 10 05-03-2009 11:12 AM
frame swap Trailer Hotrodding Basics 1 02-16-2009 06:16 PM
Frame swap NealFY Suspension - Brakes - Steering 7 01-14-2009 07:21 AM
4.3 to 5.7 swap th400 -transmission braces daveEM Transmission - Rearend 6 07-05-2008 06:49 AM
49 chevy p/u frame swap krazytrain Suspension - Brakes - Steering 6 06-22-2007 12:51 AM
