4.3 not sure - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2012, 01:50 PM
Hello
Hello !
First time logging on.
I'am currenttly removing a 4.3 from a 2000 chevy blazer. Not sure about the main wiring harness, running across the eng. Doe's the wiring need to be removed from the fuse box. On the drivers side? SO THE MOTOR CAN BE PUILLED.
Thanks
Old 08-25-2012, 01:57 PM
4.3 not sure
Not familuar with 4.3 eng. On the front of the intake,about where the dist.usually sits is a short canister, with a wire plug going into it. Three bolts hold the canister to the intake. What is this & what is its purpose.
Thanks
Old 08-25-2012, 03:04 PM
RWENUTS's Avatar
Didja' know a picture tells a thousand words!
