4.3 shot in the dark - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2010, 03:45 PM
DoubleVision's Avatar
I`m dealing with a 1997 4.3 V6. I`ve got it stripped all the way down and getting it ready for clean up and honing. I was taking a look at the heads. The tonawanda GM plant on 4.3`s switched to "net lash" valve adjustment. Since I`m going to with a Comp aftermarket roller grind it has to be changed over to adjustable. The head studs are already screw in type with threads only half way down the stud. I`ve looked at aftermarket studs that convert it and they are expensive. I`ve also thought about buying standard small block chevy studs and having the holes retapped in the heads but this would also be expensive. This is a shot in the dark but thought I`d ask. What if I took the studs on there and threaded them all the way down like a regular screw in stud is? Is this possible or am I missing something here? This would be the cheapest and easiest route. Thanks for any views on this issue.
Old 05-16-2010, 03:57 PM
Hippie's Avatar
Last journal entry: HEI comparison.
From looking at mine it looks like you would have to turn down the OD in a lathe before you could run a die down them and don't you still need a shoulder for the pivot to rest against? Plus how hard are the studs and how deep are they hardened? I don't know what the conversion studs cost but every time I try to save a few bucks this way it ends up costing me twice as much as what I was trying to save.
Old 05-16-2010, 04:03 PM
Lol that sounds like me Hippie. I`ll likely just order a set of conversion studs then and be done with it. I have to strip the heads next and run them over to my machinist so he can clearance the valve guides for the higher lift cam.
4.3 Chevy exhaust manifolds. DoubleVision Engine 5 01-26-2010 08:39 AM
swapping injectors 2003 4.3 rcrge Engine 1 05-08-2009 06:56 AM
sand vs shot in a shot bag antiquecar Body - Exterior 9 03-17-2005 09:26 AM
Shot Peening - Interesting Read dbuff Engine 0 09-02-2004 12:43 PM
4.3 to 5.7 s-10 manny tranny MartyMart9@aol.com Transmission - Rearend 2 11-03-2003 07:58 PM
