#1
4.3 v6 cam
i am rebuilding a 4.3 and the cam bearings are numbered diffrent and was wondering what sequence of numbers go where
Register now (free) or login to remove ads |
#2
Some info here >> http://www.fullthrottlev6.com/forum...n-Discrepancies
Many use SBC Cam Bearings >> http://www.chevytech.info/2c38.html |
#4
From the hotsixes site- Quote:
#8
Looking at the Part#'s I don't see anything about the w/T or wo/T on the 60* Cam Bearings but, it's there on the 90* Bearings. Part #'s are also different. |
#12
#13
So the passenger side gallery feeds the passenger side lifter bores, the larger driver side gallery handles the driver side lifters and the main bearing supply. The driver side gallery is not aligned to the center of the lifter bores like the passenger side, it's offset to the outside of the bores (see below, right. This engine also has a balance shaft). Should more be needed, the Chevy Power manual, 5th Edition has a decent drawing of the oil system, I'm not sure if the later editions do or not. |
