-   -   4.3 V6 Coil Spring Rate (http://www.hotrodders.com/forum/4-3-v6-coil-spring-rate-25430.html)
Cecil Stainback 10-10-2003 09:50 AM
Looking for advice on the coil spring rates for a 4.3 V6 set-up. Where could I find this info.
V8 S-10 10-11-2003 12:05 PM
You can try asking in the suspention forum on
http://forums.s-series.org/index.php
I don't think anybody has ever asked that question before.
willys36@aol.com 10-22-2003 03:55 PM
What kind of car?
Cecil Stainback 10-30-2003 04:16 PM
Front Coil Springs
Installing a 305 into a 1988 GMC S-15 truck short bed. Started out as a 2.5 with auto trans. Plan to keep it as an automatic but switch shifter to floor. I figure the 4 cylinder springs would be to weak. So, what about it, 4.3 liter V-6 springs that is.
Thanks for any advice given. :confused:
TooMany2count 10-30-2003 05:38 PM
I have read posts on other forums stating that some guys are putting 502's in S-10 trucks & are using the stock springs. Cant tell you what forums but it you do a search on the web I'm sure you'll find some of the posts.........joe
