Thread Tools Search this Thread share on Facebook
  #1
Old 12-28-2011, 10:54 AM
T Evans T Evans is offline
4.3 V6 manifold baffle
I have a 1994 Vortec 4.3 V6 which I'm carburating by using a cast steel 4bbl manifold. On the bottom of the manifold is a cup like baffle that's riveted on and has a small hole in the center. This baffle hits the balance shaft when I put the manifold on. Can I remove the baffle or is it needed? Thanks for any help. Tom
Register now (free) or login to remove ads
Old 12-28-2011, 11:29 AM
bondo's Avatar
bondo bondo is offline
Ayuh,... It's a heat shield to keep hot oil from heating the intake...
It's possible, you can beat a small dent in it to clear the balance shaft...
Personally, I'd modify it, rather than removin' it...
Old 12-29-2011, 08:35 AM
whyholdback whyholdback is offline
Last journal entry: update
The tin heat shield is pretty close to the manifold itself.
The best solution is the Edelbrock 4.3 Vortec intake with the '96-up heads, but you can toss the balance shaft instead.
BTW, there are cast steel cranks, but that intake manifold is cast iron, not cast steel. There are important, significant differences.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "4.3 V6 manifold baffle"
ThreadThread StarterForumRepliesLast Post
removal of pcv bafflesooperEngine3002-28-2010 05:08 PM
fuel tank baffleanglia48Body - Exterior309-28-2005 09:52 PM
oil pan bafflesquids1Engine308-21-2005 05:42 AM
SBC baffle plateEric64Engine308-18-2005 12:53 PM
Loose Baffle?dionEngine309-14-2002 06:09 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
