4.3 v6 stumbles and dies - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2012, 06:22 AM
Hey everyone, i have a 1991 carbureted 4.3 v6 (Edelbrock intake). It has Holley 465 CFM carb. When i put it in gear, it stumbles and dies. I have the timing set at 8 degrees and have the fuel pressure at 4psi. Also, the throttle is very sluggish. Any thoughts on what could be causing this??? Thanks for your help!
Old 08-02-2012, 05:50 PM
bigdog7373's Avatar
Of course it's fast
Raise the pressure to 6psi, thats what holley calls for.
Do you have vacuum advance?
The Following User Says Thank You to bigdog7373 For This Useful Post:
PULSE (08-03-2012)
Old 08-02-2012, 06:02 PM
RWENUTS's Avatar
Bump your timing up to 12-14*.
The Following User Says Thank You to RWENUTS For This Useful Post:
PULSE (08-03-2012)
Old 08-02-2012, 07:09 PM
DoubleVision's Avatar
With vacuum advance disconnected and plugged, set the timing at 12 degrees before top dead center. Lock distributor. Reconnect vac advance. Make sure you connect it to manifold vacuum source. This is any source on the carb that pulls vacuum full time, including at idle. Recheck timing, it should be 18 to 24 degrees before top dead center. If it's still at 12 then the vac advance is likely ruptured and will need replaced. When you connect it right away it will idle up. Lower the idle speed down to around 700. Then reset the idle mixture screws. With the timing set as low as you have it now the idle adjustment is so far open the throttle blades are off the idle circuit which is forcing it to idle off the main boosters. I just converted my hot rodded 4.3 from TBI to carb. I also converted it to Vortec heads and a marine intake with a Quadrajet sitting on the top and the timing specs I gave are what we use on small block chevys which are really no different tune wise than the 4.3's. I used them on my 4.3 and now when I tap the key it starts. Soon I'll have the rest of the parts I need and I'll be able to test drive it finally. Once you get the timing set correctly you'll notice it has alot more power and it'll get better fuel mileage as well.
The Following User Says Thank You to DoubleVision For This Useful Post:
PULSE (08-03-2012)
Old 08-03-2012, 12:23 AM
Sorry for the time delay I’m in Africa. Over the weekend I will defiantly bump up the fuel pressure and reset the timing . at this stage the vacuum is connected to the carb but I will change that. Thank you for your reply hope I can sort this thing out.
Old 08-03-2012, 05:03 AM
Some holleys can handle up to 9 psi. Some can't handle more than 6. In my experience any time I moved one up past 6 it started flooding. Move yours up to about 5 1/2 psi as a safe point.
Old 08-03-2012, 05:23 AM
Thank you will do will let you know on Monday how things went
Old 08-10-2012, 01:44 PM
bigdog7373's Avatar
Of course it's fast
update? how'd it work out?
Old 08-13-2012, 08:53 AM
Running like new thank you every one
SBC stumbles/dies under load - Enigma, ready to torch it! highgrade Engine 30 02-01-2012 03:11 PM
M4ME carb stumbles sometimes dies when letting off throttle in gear fast68 Engine 4 08-29-2007 05:57 AM
Carb stumbles "70" Cougar Engine 16 08-06-2007 05:41 PM
Eldo stumbles pmeisel Transmission - Rearend 2 07-02-2007 06:23 AM
Another noob stumbles in Der Bugmeister Introduce Yourself 4 12-27-2005 10:25 PM
