4.3 V6 water pumps - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2007, 01:03 PM
4.3 V6 water pumps
I am working on a 2005 Chev. 4.3 V6 to go into a street rod.
As the 4.3 is basically a 350 V8 less two cylinders, will a water pump for the V8 fit the V6?
Am I correct in assuming that this application would require a "long" water pump? If memory serves me correctly, the short water pump was used on passenger cars through 1968 and trucks through 1972.
Old 10-23-2007, 01:11 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Yup, the pumps interchange. I'm 99% sure it would be a long pump. They used to keep short pumps around in some applications, but I think that died in the 70s. Everything (except vettes) should be a long pump.
Old 10-23-2007, 06:52 PM
You didn't say if you were running the original serpentine belt or converting to V belt, but whichever, make sure the pump rotation is correct. The stock pump is reverse rotation. V belt drive pumps should be "standard" rotation. Just something to consider.
Bob
Old 10-23-2007, 06:53 PM
curtis73's Avatar
Wiki Edits: 16
good catch
bore & stroke a GM 4.3 V6 awannf Engine 11 11-08-2009 05:34 PM
bbc water pumps 68chevelle_ss Engine 7 04-24-2004 04:17 AM
4.3 V6 identification tjh211 Engine 3 12-30-2003 04:19 PM
4.3 V6 Coil Spring Rate Cecil Stainback Suspension - Brakes - Steering 4 10-30-2003 05:38 PM
Hi Volume Water Pumps jpspridd Engine 4 08-20-2002 09:55 AM
