Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4.3 vortec
Thread: 4.3 vortec
Old 01-22-2013, 01:18 PM
MouseFink MouseFink is offline
Originally Posted by bernard landry View Post
which trans and componets will adapt as the 93 is externally balanced it had a 4 wheel dr trans when i got but the application has changed to street rod tks bl
All Chevy V6/V8 engines with a one-piece rear seal are internally balanced. Many people think the engine is externally balanced because the flex plate used on those engines has a counter weight. The counter weight was placed on the flex plate in order to compensate for the lack of a counter weight on the one-piece seal rear main flange. You must use a counter-weighted flex plate on crankshafts having a one-piece rear seal because the crankshaft flange bolt pattern is different from the flex -plates that do not have a counter-weight. That feature keeps people from using the wrong flex-plate.
