4.3 vortec - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2013, 10:09 PM
4.3 vortec
hi can a 4.3 1995 vortec be carburated tks bl
Old 01-20-2013, 10:23 PM
vinniekq2's Avatar
just about everything can be carbed
Old 01-20-2013, 10:28 PM
just about dosent work
Old 01-20-2013, 10:37 PM
vinniekq2's Avatar
Edelbrock 2111 - Edelbrock Performer Intake Manifolds for Chevy Details
Chevy 200/229/262ci 3.8L/4.3L 90 V6
Designed for street 1985-95 Chevy 3.8L and 4.3L V6 200/229/262ci. Does not accept stock automotive carbs or 262 TBI unit. Dual bolt pattern water neck fits both automotive and marine applications (produced 18 HP more than older manifold design on 4.3L marine engine)
not like a 4.3 is rare,,,
Old 01-21-2013, 12:14 PM
BOBCRMAN@aol.com's Avatar
4.3's can be a real problem with aftermkt intakes. From 1995 on there are several different intake/head configurations. The bolts don't line up.
Old 01-21-2013, 05:35 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
As long as it's a '95 model year and not a '95 casting date, you're good to go w/the 2111 or an OEM cast iron Q-jet intake.
Now, heads w/a '95 casting date might still be OK, but it could also be a '96 production, and that would make it a "true" Vortec head. The Vortec head takes a totally different intake than the '95-back model year heads.
Old 01-22-2013, 12:51 AM
trannys
which trannys and componets are compatable with a 4.3 1993 vortec
Old 01-22-2013, 03:49 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
700R4's and T5's.Well that is what is stock behind the 1993.
Surprised no one has said with you wanting to go carb,you have to change to a non-computer dizzy.This is a brand new re-curved one I have that never got used for a 4.3.PM me if interested.
Old 01-22-2013, 08:29 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Small world- I have by me as I type the same application distributor (#1110754), also w/lighter springs.
But "brand new"??
Old 01-22-2013, 11:45 AM
1993 4.3 now carbed
which trans and componets will adapt as the 93 is externally balanced it had a 4 wheel dr trans when i got but the application has changed to street rod tks bl
Old 01-22-2013, 11:49 AM
bondo's Avatar
Ayuh,.... There's several different balancers/ flywheels/ flexplates used on the 4.3l, but it don't care which transmission ya used,...
Chevy bellhousin' patterns are the Same...
Old 01-22-2013, 01:27 PM
1Gary's Avatar
But "brand new"??
Yeah-it's been setting on the shelf in the shop for yrs.Bought it new and had Jan-Cen auto re-curve it on their Sun machine.
Old 01-22-2013, 02:18 PM
All Chevy V6/V8 engines with a one-piece rear seal are internally balanced. Many people think the engine is externally balanced because the flex plate used on those engines has a counter weight. The counter weight was placed on the flex plate in order to compensate for the lack of a counter weight on the one-piece seal rear main flange. You must use a counter-weighted flex plate on crankshafts having a one-piece rear seal because the crankshaft flange bolt pattern is different from the flex -plates that do not have a counter-weight. That feature keeps people from using the wrong flex-plate.
1998 350 Vortec Swap to 2000 454 vortec Bobbydnovaman Engine 5 12-20-2012 12:19 AM
putting 305 vortec heads on an pre-vortec 350 thor1022 Engine 11 01-12-2011 04:17 PM
im converting a 96 350 vortec and putting in a 99 454 vortec rkoontz93 Introduce Yourself 1 05-11-2010 04:26 PM
305 vortec heads vs 350 vortec rimracers Engine 6 04-02-2007 09:41 PM
Identifying Vortec from non-Vortec engines? RDR800 Engine 4 07-07-2006 09:09 PM
