In my truck, which is a 92 chevy silverado, it had developed a leaky door seal. Everytime it would rain or have high humidity, the radio wouldn`t work. I pulled the radio out and found the power wire was not suppling any power at all. I further traced the wire to the fuse panel which I had to remove and clean. It kinda sounds like in your case the ignition is either not sparking or it`s too weak to fire it off, the excessive fuel on the plugs can be a indication of this. You may also want to check the vacuum signal to the map sensor. Make sure the vacuum line isn`t broken or plugged, also make sure it`s pulling vacuum. Do a spark test, if the spark is yellow it`s weak and there`s a problem in the ignition.
